New interface
Journal articles
Interval observer design and control of uncertain non-homogeneous heat equations
Abstract : The problems of state estimation and observer-based control for heat non-homogeneous equations under distributed in space point measurements are considered. First, an interval observer is designed in the form of Partial Differential Equations (PDEs), without Galerkin projection. Second, conditions of boundedness of the interval observer solutions with non-zero boundary conditions and measurement noise are proposed. Third, the obtained interval estimates are used to design a dynamic output-feedback stabilizing controller. The advantages of the PDE-based interval observer over the approximation-based one are clearly shown in the numerical example.
Document type :
Journal articles
Complete list of metadata
Cited literature [42 references]  Display  Hide  Download
https://hal.inria.fr/hal-02283008
Contributor : Denis Efimov Connect in order to contact the contributor
Submitted on : Tuesday, September 10, 2019 - 1:39:48 PM
Last modification on : Tuesday, November 22, 2022 - 2:26:16 PM
Long-term archiving on: : Friday, February 7, 2020 - 11:13:35 PM
File
_Interval_PDE_J_2_new_contr_2_...
Identifiers
Citation
Tatiana Kharkovskaia, Denis Efimov, Emilia Fridman, Andrey Polyakov, Jean-Pierre Richard. Interval observer design and control of uncertain non-homogeneous heat equations. Automatica, 2020, 111, ⟨10.1016/j.automatica.2019.108595⟩. ⟨hal-02283008⟩
Share
Metrics
Record views
158
Files downloads
247
