Adaptive Mesh Texture for Multi-View Appearance Modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we report on the representation of appearance information in the context of 3D multi-view shape modeling. Most applications in image based 3D modeling resort to texture maps, a 2D mapping of shape color information into image files. Despite their unquestionable merits, in particular the ability to apply standard image tools, including compression, image textures still suffer from limitations that result from the 2D mapping of information that originally belongs to a 3D structure. This is especially true with 2D texture atlases, a generic 2D mapping for 3D mesh models that introduces discontinuities in the texture space and plagues many 3D appearance algorithms. Moreover, the per-triangle texel density of 2D image textures cannot be individually adjusted to the corresponding pixel observation density without a global change in the atlas mapping function. To address these issues, we propose a new appearance representation for image-based 3D shape modeling, which stores appearance information directly on 3D meshes, rather than a texture atlas. We show this representation to allow for input-adaptive sampling and compression support. Our experiments demonstrate that it outperforms traditional image textures, in multi-view reconstruction contexts, with better visual quality and memory footprint, which makes it a suitable tool when dealing with large amounts of data as with dynamic scene 3D models.
3dv2019submission.pdf (9.06 Mo) Télécharger le fichier
hal-02284101 , version 1 (11-09-2019)
Matthieu Armando, Jean-Sébastien Franco, Edmond Boyer. Adaptive Mesh Texture for Multi-View Appearance Modeling. 3DV 2019 - 7th International Conference on 3D Vision, Sep 2019, Quebec City, Canada. pp.700-708, ⟨10.1109/3DV.2019.00082⟩. ⟨hal-02284101⟩
241 Consultations
661 Téléchargements
