Pyramid Escape: Design of Novel Passive Haptics Interactions for an Immersive and Modular Scenario - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present the design of ten different 3D user interactions using passive haptics and embedded in an escape game scenario in which users have to escape from a pyramid in a limited time. Our solution is innovative by its modularity, allowing interactions with virtual objects using tangible props manipulated either directly using the hands and feet or indirectly through a single prop held in the hand, in order to perform several interactions with the virtual environment (VE). We also propose a navigation technique based on the “impossible spaces” design, allowing users to naturally walk through several overlapping rooms of the VE. All together, our different interaction techniques allow the users to solve several enigmas built into a challenging scenario inside a pyramid.
HybridTeam_3DUIContest2019_CameraReady.pdf (36.04 Mo) Télécharger le fichier
hal-02284129 , version 1 (11-09-2019)
hal-02284129 , version 2 (08-10-2019)
Hugo Brument, Rebecca Fribourg, Gerard Gallagher, Thomas M. Howard, Flavien Lécuyer, et al.. Pyramid Escape: Design of Novel Passive Haptics Interactions for an Immersive and Modular Scenario. VR 2019 - 26th IEEE Conference on Virtual Reality and 3D User Interfaces, Mar 2019, Osaka, Japan. pp.1409-1410, ⟨10.1109/VR.2019.8797848⟩. ⟨hal-02284129v2⟩
255 Consultations
61 Téléchargements
