Abstract : In this work a numerical method is proposed to compress a tensor by constructing a piece-wise tensor approximation. This is defined by partitioning a tensor into sub-tensors and by computing a low-rank tensor approximation (in a given format) in each sub-tensor. Neither the partition nor the ranks are fixed a priori, but, instead, are obtained in order to fulfill a prescribed accuracy and optimize, to some extent, the storage. The different steps of the method are detailed and some numerical experiments are proposed to assess its performances.
