, F.; and by the São Paulo Research Foundation (FAPESP)
Reconstruction of genome-scale active metabolic networks for 69 human cell types and 16 cancer types using INIT, PLoS Comput. Biol, vol.8, p.1002518, 2012. ,
Integration of gene expression data into genome-scale metabolic models, Metab. Eng, vol.6, pp.285-293, 2004. ,
Keypathwayminer: detecting case-specific biological pathways using expression data, Internet Math, vol.7, pp.299-313, 2011. ,
Efficient key pathway mining: combining networks and OMICS data, Integr. Biol, vol.4, pp.756-764, 2012. ,
KEGG spider: interpretation of genomics data in the context of the global gene metabolic network, Genome Biol, vol.9, p.179, 2008. ,
Trehalose promotes the survival of Saccharomyces cerevisiae during lethal ethanol stress, but does not influence growth under sublethal ethanol stress, FEMS Yeast Res, vol.9, pp.1208-1216, 2009. ,
Efficient algorithms for extracting biological key pathways with global constraints, Proceedings of the 14th Annual Conference on Genetic and Evolutionary Computation, GECCO '12, pp.169-176, 2012. ,
Context-specific metabolic networks are consistent with experiments, PLoS Comput. Biol, vol.4, p.1000082, 2008. ,
Methionine metabolism alters oxidative stress resistance via the pentose phosphate pathway, Antioxid. Redox Signal, vol.24, pp.543-547, 2016. ,
Probabilistic integrative modeling of genome-scale metabolic and regulatory networks in Escherichia coli and Mycobacterium tuberculosis, Proc. Natl. Acad. Sci. USA, vol.107, pp.17845-17850, 2010. ,
Protective effects of arginine on Saccharomyces cerevisiae against ethanol stress, Sci. Rep, vol.6, p.31311, 2016. ,
Stoichiometric network analysis, Cell Biophys, vol.12, pp.237-253, 1988. ,
Interpreting expression data with metabolic flux models: predicting Mycobacterium tuberculosis mycolic acid production, PLoS Comput. Biol, vol.5, p.1000489, 2009. ,
Temporal expression-based analysis of metabolism, PLoS Comput. Biol, vol.8, p.1002781, 2012. ,
Constraints-based models: regulation of gene expression reduces the steady-state solution space, J. Theor. Biol, vol.221, pp.309-325, 2003. ,
Tolerance and stress response to ethanol in the yeast Saccharomyces cerevisiae, Appl. Microbiol. Biotechnol, vol.85, pp.253-263, 2009. ,
Modeling phenotypic metabolic adaptations of Mycobacterium tuberculosis H37Rv under hypoxia, PLoS Comput. Biol, vol.8, p.1002688, 2012. ,
Escherichia coli acid resistance: tales of an amateur acidophile, Nat. Rev. Microbiol, vol.2, pp.898-907, 2004. ,
Creation and analysis of biochemical constraint-based models using the COBRA Toolbox v.3.0, Nat. Protoc, vol.14, pp.639-702, 2019. ,
A glutamate-dependent acid resistance gene in Escherichia coli, J. Bacteriol, vol.178, pp.3978-3981, 1996. ,
Discovering regulatory and signalling circuits in molecular interaction networks, Bioinformatics, vol.18, pp.233-240, 2002. ,
Functional integration of a metabolic network model and expression data without arbitrary thresholding, Bioinformatics, vol.27, pp.541-547, 2011. ,
Computational reconstruction of tissue-specific metabolic models: application to human liver metabolism, Mol. Syst. Biol, vol.6, p.401, 2010. ,
Antisense-mediated inhibition of acid trehalase (ATH1) gene expression promotes ethanol fermentation and tolerance in Saccharomyces cerevisiae, Biotechnol. Lett, vol.27, pp.1855-1859, 2005. ,
Flux-coupled genes and their use in metabolic flux analysis, Biotechnol. J, vol.8, pp.1035-1042, 2013. ,
Methods for integration of transcriptomic data in genome-scale metabolic models, Comput. Struct. Biotechnol. J, vol.11, pp.59-65, 2014. ,
E-Flux2 and SPOT: validated methods for inferring intracellular metabolic flux distributions from transcriptomic data, PLoS One, vol.11, p.157101, 2016. ,
BiGG Models: a platform for integrating, standardizing and sharing genome-scale models, Nucleic Acids Res, vol.44, pp.515-522, 2016. ,
Hypergraphs and cellular networks, PLoS Comput. Biol, vol.5, p.1000385, 2009. ,
An introduction to metabolic networks and their structural analysis, IEEE/ACM Trans. Comput. Biol. Bioinform, vol.5, pp.594-617, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00355497
Correction to: transcriptional responses of Escherichia coli during recovery from inorganic or organic mercury exposure, BMC Genomics, vol.19, p.268, 2018. ,
Improving metabolic flux predictions using absolute gene expression data, BMC Syst. Biol, vol.6, p.73, 2012. ,
EBSeq: an empirical Bayes hierarchical model for inference in RNA-seq experiments, Bioinformatics, vol.29, pp.1035-1043, 2013. ,
Systematic evaluation of methods for integration of transcriptomic data into constraint-based models of metabolism, PLoS Comput. Biol, vol.10, p.1003580, 2014. ,
Connecting extracellular metabolomic measurements to intracellular flux states in yeast, BMC Syst. Biol, vol.3, p.37, 2009. ,
Linking high-resolution metabolic flux phenotypes and transcriptional regulation in yeast modulated by the global regulator Gcn4p, Proc. Natl. Acad. Sci. USA, vol.106, pp.6477-6482, 2009. ,
Automated extraction of meaningful pathways from quantitative proteomics data, Brief. Funct. Genomic Proteomic, vol.7, pp.136-146, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00767067
A comprehensive comparison of RNA-Seq-based transcriptome analysis from reads to differential gene expression and cross-comparison with microarrays: a case study in Saccharomyces cerevisiae, Nucleic Acids Res, vol.40, pp.10084-10097, 2012. ,
A systematic evaluation of methods for tailoring genome-scale metabolic models, Cell Syst, vol.4, pp.318-329, 2017. ,
What is flux balance analysis?, Nat. Biotechnol, vol.28, pp.245-248, 2010. ,
A comprehensive genome-scale reconstruction of Escherichia coli metabolism-2011, Mol. Syst. Biol, vol.7, p.535, 2011. ,
Reactive oxygen species production induced by ethanol in Saccharomyces cerevisiae increases because of a dysfunctional mitochondrial iron-sulfur cluster assembly system, FEMS Yeast Res, vol.13, pp.804-819, 2013. ,
Advances in network-based metabolic pathway analysis and gene expression data integration, Brief. Bioinform, vol.16, pp.265-279, 2015. ,
Context-specific metabolic model extraction based on regularized least squares optimization, PLoS One, vol.10, p.131875, 2015. ,
Inferring metabolic states in uncharacterized environments using gene-expression measurements, PLoS Comput. Biol, vol.9, p.1002988, 2013. ,
Recent advances in the reconstruction of metabolic models and integration of omics data, Curr. Opin. Biotechnol, vol.29, pp.39-45, 2014. ,
Linking metabolic network features to phenotypes using sparse group lasso, Bioinformatics, vol.33, pp.3445-3453, 2017. ,
Genotype-by-environment-by-environment interactions in the Saccharomyces cerevisiae transcriptomic response to alcohols and anaerobiosis, G3 (Bethesda), vol.8, pp.3881-3890, 2018. ,
Reconstruction of tissue-specific metabolic networks using CORDA, PLoS Comput. Biol, vol.12, p.1004808, 2016. ,
YANA -a software tool for analyzing flux modes, gene-expression and enzyme activities, BMC Bioinformatics, vol.6, p.135, 2005. ,
Discovering molecular pathways from protein interaction and gene expression data, Bioinformatics, vol.19, pp.264-271, 2003. ,
Network-based prediction of human tissue-specific metabolism, Nat. Biotechnol, vol.26, pp.1003-1010, 2008. ,
Regulation of trehalose mobilization in fungi, Microbiol. Rev, vol.48, pp.42-59, 1984. ,
Integrating proteomic or transcriptomic data into metabolic models using linear bound flux balance analysis, Bioinformatics, vol.34, pp.3882-3888, 2018. ,
Representing and analysing molecular and cellular function using the computer, Biol. Chem, vol.381, pp.921-935, 2000. ,
Advances in the integration of transcriptional regulatory information into genome-scale metabolic models, Biosystems, vol.147, pp.1-10, 2016. ,
Fast reconstruction of compact context-specific metabolic network models, PLoS Comput. Biol, vol.10, p.1003424, 2014. ,
Reconstruction of genome-scale metabolic models for 126 human tissues using mCADRE, BMC Syst. Biol, vol.6, p.153, 2012. ,
Phenotype-based cell-specific metabolic modeling reveals metabolic liabilities of cancer, Elife, vol.3, p.3641, 2014. ,
Prediction of metabolic fluxes from gene expression data with Huber penalty convex optimization function, Mol. Biosyst, vol.13, pp.901-909, 2017. ,
A computational method using differential gene expression to predict altered metabolism of multicellular organisms, Mol. Biosyst, vol.13, pp.2418-2427, 2017. ,
Redox status expressed as GSH: GSSG ratio as a marker for oxidative stress in paediatric tumour patients, Oncol. Lett, vol.4, pp.1247-1253, 2012. ,
iMAT: an integrative metabolic analysis tool, Bioinformatics, vol.26, pp.3140-3142, 2010. ,
