Fault Detection , Isolation , and Service Restoration in Distribution Systems : State-of-the-Art and Future Trends, IEEE Trans. Smart Grid, vol.8, issue.5, pp.2170-2185, 2017. ,
Localization of Faults in Low Voltage Networks by Graph Method, IEEE Int. Symp. Appl. Comput. Intell, vol.11, pp.397-400, 2016. ,
DGs for Service Restoration to Critical Loads in a Secondary Network, IEEE Trans. Smart Grid, issue.8, 2017. ,
Faults Detection in Power Systems Using Artificial Neural Network, Am. J. Eng. Res, vol.02, issue.06, pp.2320-847, 2013. ,
Faults Monitoring System in the Electric Power Grid of Medium Voltage, Procedia Comput. Sci, vol.130, pp.696-703, 2018. ,
Visions, Scenarios and Action Plans Towards Next Generation Tanzania Power System, pp.3908-3927, 2012. ,
Fault Detection and Location in Low Voltage Grids Based on RFMesh Sensor Networks, CIRED Workshop, pp.1-4, 2016. ,
Parallel and Distributed Processing of Power Systems, Communication and Control in Electric Power Systems, pp.47-100, 2005. ,
On distributed computing for on-line power system applications, Int. J. Electr. Power Energy Syst, vol.18, issue.8, pp.527-533, 1996. ,
The Impact of Industry Participation on Challenge Based Learning *, Int. J. Eng. Educ, vol.34, issue.1, pp.187-200, 2018. ,
Understanding engineering education change with the introduction of challenge driven education in Tanzania, IEEE Glob. Eng. Educ. Conf. EDUCON, pp.1335-1343, 2018. ,
Fault diagnosis on medium voltage (MV) electric power distribution networks: The case of the downstream network of the AES-SONEL Ngousso sub-station, Energies, vol.2, issue.2, pp.243-257, 2009. ,
A review on fault classification methodologies in power transmission systems: Part-I, J. Electr. Syst. Inf. Technol, vol.5, issue.1, pp.48-60, 2017. ,
The Fault Location Method of DistributionNetwork with Fault Indicators Based on Impedance, International Conference on AMCCE, pp.386-391, 2015. ,
An Improved Fault Location Method for Distribution Networks Exploiting Emerging LV Smart Meters, IEEE Workshop on Environmental, Energy, and Structural Monitoring Systems, pp.1-6, 2016. ,
Fault Location in Distribution Networks by Compressive Sensing, IEEE Trans. Power Deliv, vol.30, issue.4, pp.1761-1769, 2015. ,
Distribution network fault section identification and fault location using wavelet entropy and neural networks, Appl. Soft Comput. J, vol.46, pp.296-306, 2016. ,
Identification of Faulted Feeder Section in Distribution Systems Using Overcurrent Information from Switching Devices, Int. J. Emerg. Electr. Power Syst, vol.15, issue.2, pp.171-176, 2014. ,
Applications and Trends of High Performance Computing for Electric Power Systems: Focusing on Smart Grid, IEEE Trans. Smart Grid, vol.4, issue.2, pp.922-931, 2013. ,
Implementation Requirements for automated Fault Data Analytics in Power Systems, Int. Trans. Electr. Energy Syst, vol.36, pp.51-66, 2014. ,
SCADA design in automation systems, 3rd Int. Conf. Hum. Syst. Interact. HSI'2010 -Conf. Proc, pp.695-700, 2010. ,
Advances in SCADA and RTU Technology for Next Generation Operators, 2014. ,
The Future of SCADA System, Florida Water Resour. J, vol.1, pp.30-34, 2011. ,
An Extended Fault Location Formulation for Unbalanced Distribution Feeders with Distributed Generation, 2010. ,
Fault Diagnosis on Distribution System Using PLC & SCADA, Int. J. Innov. Res. Sci. Eng. Technol, vol.6, issue.11, pp.21393-21401, 2017. ,
A cost-effective fault management system for distribution systems with distributed generators, Int. J. Electr. Power Energy Syst, vol.65, pp.357-366, 2015. ,
High performance computing or detection of electricity theft, Int. J. Electr. Power Energy Syst, vol.47, pp.21-30, 2013. ,
