A Surrogate-Assisted Multi-fidelity Measure Approximation Framework for Efficient Constrained Multiobjective Optimization Under Uncertainty - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The SABBa framework has been shown to tackle multi-objective optimization under uncertainty problems efficiently. It deals with robust and reliability-based optimization problems with approximated robustness and reliability measures. The recursive aspect of the Bounding-Box (BB) approach has notably been exploited in [1], [2] and [3] with an increasing number of additional features, allowing for little computational costs. In these contributions, robustness and reliability measures are approximated by a Bounding-Box (or conservative box), which is roughly a uniform-density representation of the unknown objectives and constraints. It is supplemented with a surrogate-assisting strategy, which is very effective to reduce the overall computational cost, notably during the last iterations of the optimization. In [3], SABBa has been quantitatively compared to more classical approaches with much success both concerning convergence rate and convergence robustness. We propose in this work to further improve the parsimony of the approach with a more general framework, SAMMA (Surrogate-Assisted Multi-fidelity Measure Approximation), allowing for objects other than Bounding-Boxes to be compared in the recursive strategy. Such non-uniform approximations have been proposed in some previous works like [4] and [5]. Among others, the empirical sampling and Gaussian measure approximations are presented and quantitatively compared in the following. We propose suitable Pareto dominance rules and POP (Pareto Optimal Probability) computations for these new measure approximations. To extend the framework applicability to complex industrial cases, and alongside the multi-fidelity between different UQs (Uncertainty Quantification) inherent to the recursive strategy, we propose to plug multi-fidelity approaches within the measure computations. This approach should allow tackling very complex industrial problems in an acceptable timeframe.
Fichier non déposé
hal-02286156 , version 1 (09-05-2022)
  • HAL Id : hal-02286156 , version 1
Mickael Rivier, Pietro Marco Congedo. A Surrogate-Assisted Multi-fidelity Measure Approximation Framework for Efficient Constrained Multiobjective Optimization Under Uncertainty. UNCECOMP 2019 - 3rd International Conference on Uncertainty Quantification in Computational Sciences and Engineering, Jun 2019, Hersonissos, Greece. ⟨hal-02286156⟩
90 Consultations
0 Téléchargements
