HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Survivor: A Fine-Grained Intrusion Response and Recovery Approach for Commodity Operating Systems
Ronny Chevalier 1, 2 David Plaquin 1 Chris Dalton 1 Guillaume Hiet 2
2 CIDRE - Confidentialité, Intégrité, Disponibilité et Répartition
CentraleSupélec, Inria Rennes – Bretagne Atlantique , IRISA-D1 - SYSTÈMES LARGE ÉCHELLE
Abstract : Despite the deployment of preventive security mechanisms to protect the assets and computing platforms of users, intrusions eventually occur. We propose a novel intrusion survivability approach to withstand ongoing intrusions. Our approach relies on an orchestration of fine-grained recovery and per-service responses (e.g., privileges removal). Such an approach may put the system into a degraded mode. This degraded mode prevents attackers to reinfect the system or to achieve their goals if they managed to reinfect it. It maintains the availability of core functions while waiting for patches to be deployed. We devised a cost-sensitive response selection process to ensure that while the service is in a degraded mode, its core functions are still operating. We built a Linux-based prototype and evaluated the effectiveness of our approach against different types of intrusions. The results show that our solution removes the effects of the intrusions, that it can select appropriate responses, and that it allows services to survive when reinfected. In terms of performance overhead, in most cases, we observed a small overhead, except in the rare case of services that write many small files asynchronously in a burst, where we observed a higher but acceptable overhead.
Document type :
Conference papers
Complete list of metadata
Cited literature [69 references]  Display  Hide  Download
https://hal.inria.fr/hal-02289315
Contributor : Ronny Chevalier Connect in order to contact the contributor
Submitted on : Thursday, September 26, 2019 - 12:46:09 PM
Last modification on : Monday, April 4, 2022 - 9:28:21 AM
Identifiers
Citation
Ronny Chevalier, David Plaquin, Chris Dalton, Guillaume Hiet. Survivor: A Fine-Grained Intrusion Response and Recovery Approach for Commodity Operating Systems. ACSAC 2019 - 35th Annual Computer Security Applications Conference, Dec 2019, San Juan, Puerto Rico. ⟨10.1145/3359789.3359792⟩. ⟨hal-02289315v2⟩
Share
Metrics
Record views
187
Files downloads
225
