SAKURA a Model Based Root Cause Analysis Framework for vIMS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2019
Model based machine learning (MBML) techniques solve novel diagnosis problems and provide explanations for their decisions. However, current MBMLs suffer some limitations, since virtualization of network brings new challenges such as the dynamic topology and elasticity. Those limitations include the high dependency on previous knowledge and the difficulty to represent the model. To face those limitations, we propose SAKURA: a root cause analysis framework for the virtual Ip Multimedia Subsystem (vIMS). SAKURA is composed of a self-modeling and a constraints solver algorithm.
poster__Sakura(19).pdf (608.2 Ko) Télécharger le fichier
hal-02291163 , version 1 (18-10-2019)
  • HAL Id : hal-02291163 , version 1
Sihem Cherrared, Sofiane Imadali, Eric Fabre, Gregor Gössler. SAKURA a Model Based Root Cause Analysis Framework for vIMS. MobiSys 2019 - 17th ACM International Conference on Mobile Systems, Applications, and Services, Jun 2019, Seoul, South Korea. ACM Press, pp.594-595. ⟨hal-02291163⟩
182 Consultations
191 Téléchargements
