Weighted Linear Bandits for Non-Stationary Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Claire Vernade
We consider a stochastic linear bandit model in which the available actions correspond to arbitrary context vectors whose associated rewards follow a non-stationary linear regression model. In this setting, the unknown regression parameter is allowed to vary in time. To address this problem, we propose D-LinUCB, a novel optimistic algorithm based on discounted linear regression, where exponential weights are used to smoothly forget the past. This involves studying the deviations of the sequential weighted least-squares estimator under generic assumptions. As a by-product, we obtain novel deviation results that can be used beyond non-stationary environments. We provide theoretical guarantees on the behavior of D-LinUCB in both slowly-varying and abruptly-changing environments. We obtain an upper bound on the dynamic regret that is of order d^{2/3} B_T^{1/3}T^{2/3}, where B_T is a measure of non-stationarity (d and T being, respectively, dimension and horizon). This rate is known to be optimal. We also illustrate the empirical performance of D-LinUCB and compare it with recently proposed alternatives in simulated environments.
main.pdf (475.33 Ko) Télécharger le fichier
hal-02291460 , version 1 (18-09-2019)
hal-02291460 , version 2 (19-03-2020)
Yoan Russac, Claire Vernade, Olivier Cappé. Weighted Linear Bandits for Non-Stationary Environments. NeurIPS 2019 - 33rd Conference on Neural Information Processing Systems, Dec 2019, Vancouver, Canada. ⟨hal-02291460v1⟩
198 Consultations
622 Téléchargements
