High-Order Methods for CFD, pp.1-54, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01444075
Fluctuation splitting schemes for the compressible and incompressible Euler and Navier-Stokes equations, International Journal of Computational Fluid Dynamics, vol.14, issue.1, pp.21-39, 2000. ,
An unstructured, three-dimensional, shock-fitting solver for hypersonic flows, Computers & Fluids, vol.73, pp.162-174, 2013. ,
A mass-matrix formulation of unsteady fluctuation splitting schemes consistent with Roe's parameter vector, International Journal of Computational Fluid Dynamics, vol.27, issue.4-5, pp.210-227, 2013. ,
Convergence analysis of shock-capturing and shockfitting solutions on unstructured grids, AIAA journal, vol.52, issue.7, pp.1404-1416, 2014. ,
Ad-Hoc Boundary Conditions for CFD Analyses of Turbomachinery Problems With Strong Flow Gradients at Farfield Boundaries, Journal of Turbomachinery, vol.133, issue.4, pp.41010-041010, 2011. ,
Residual Distribution Schemes: Foundations and Analysis, pp.1-53, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-00402592
The shifted boundary method for embedded domain computations. Part I: Poisson and Stokes problem, Journal of Computational Physics, vol.372, pp.972-995, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01824103
The shifted boundary method for embedded domain computations. Part II: Linear advection-diffusion and incompressible Navier-Stokes equations, Journal of Computational Physics, vol.372, pp.996-1026, 2018. ,
A frontal approach for internal node generation in Delaunay triangulations, International Journal for Numerical Methods in Fluids, vol.17, issue.3, pp.241-255, 1993. ,
Shock Fitting: Classical Techniques, Recent Developments, and Memoirs of Gino Moretti, 2017. ,
A shock-fitting technique for 2D unstructured grids, Computers & Fluids, vol.38, issue.3, pp.715-726, 2009. ,
Shock interaction computations on unstructured, two-dimensional grids using a shock-fitting technique, Journal of Computational Physics, vol.230, issue.8, pp.3155-3177, 2011. ,
Triangle: Engineering a 2D quality mesh generator and Delaunay triangulator, Workshop on Applied Computational Geometry, pp.203-222, 1996. ,
The shifted boundary method for hyperbolic systems: Embedded domain computations of linear waves and shallow water flows, Journal of Computational Physics, vol.369, pp.45-79, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01793474
