I/O-ecient batched union-nd and its applications to terrain analysis, twenty-second annual symposium on Computational geometry, pp.167-176, 2006. ,
A topological hierarchy for functions on triangulated surfaces, IEEE Transactions on Visualization and Computer Graphics, vol.10, issue.4, p.385396, 2004. ,
Stability of Persistence Diagrams. Discrete and Computational Geometry, vol.37, p.103120, 2007. ,
Extending persistence using Poincaré and Lefschetz duality, Foundations of Computational Mathematics, 2008. ,
Vines and vineyards by updating persistence in linear time, SCG '06: Proceedings of the twenty-second annual symposium on Computational geometry, p.119126, 2006. ,
Loops in Reeb graphs of 2-manifolds, Proc. 19th Ann. Sympos, p.344350, 2003. ,
Hierarchical morse-smale complexes for piecewise linear 2-manifolds. Discrete and Computational Geometry, vol.30, p.87107, 2003. ,
Topological Persistence and Simplication. Discrete and Computational Geometry, vol.28, p.511533, 2002. ,
Persistence-Sensitive Simplication of Functions on 2-Manifolds, 22nd Annual ACM Symposium on Computational Geometry, p.127134, 2006. ,
Trans-dichotomous algorithms for minimum spanning trees and shortest paths, Journal of Computer System Sciences, vol.48, issue.3, p.533551, 1994. ,
A linear-time algorithm for a special case of disjoint set union, Journal of Computer and System Sciences, vol.30, issue.2, p.209221, 1985. ,
Topologybased simplication for feature extraction from 3D scalar elds, Proceedings of the IEEE Visualization Conference, p.275280, 2005. ,
Algebraic Topology, 2002. ,
Two linear time algorithms for mst on minor closed graph classes, Archivum Mathematicum, vol.40, p.315320, 2004. ,
Homological Illusions of Persistence and Stability, 2008. ,
Elements of Algebraic Topology, 1984. ,
Sur les points singuliers d'une forme de Pfa complèment intégrable ou d'une fonction numérique, Comptes Rendus de L'Académie des Séances, vol.222, p.847849, 1946. ,
Number 44 in CBMS-NFS Regional conference series in applied mathematics, 1983. ,
Computing Persistent Homology. Discrete and Computational Geometry, vol.33, p.249274, 2005. ,
