Automatic Identification and Normalisation of Physical Measurements in Scientific Literature
We present Grobid-quantities, an open-source application for extracting and normalising measurements from scientific and patent literature. Tools of this kind, aiming to understand and make un-structured information accessible, represent the building blocks for large-scale Text and Data Mining (TDM) systems. Grobid-quantities is a module built on top of Grobid [6] [13], a machine learning framework for parsing and structuring PDF documents. Designed to process large quantities of data, it provides a robust implementation accessible in batch mode or via a REST API. The machine learning engine architecture follows the cascade approach, where each model is specialised in the resolution of a specific task. The models are trained using CRF (Conditional Random Field) algorithm [12] for extracting quantities (atomic values, intervals and lists), units (such as length, weight) and different value representations (nu-meric, alphabetic or scientific notation). Identified measurements are normalised according to the International System of Units (SI). Thanks to its stable recall and reliable precision, Grobid-quantities has been integrated as the measurement-extraction engine in various TDM projects, such as Marve (Measurement Context Extraction from Text), for extracting semantic measurements and meaning in Earth Science
Automatic_Identification_and_Normalisation_of_Physical_Measurements_in_Scientific_Literature (1).pdf (508.22 Ko)
Télécharger le fichier
presentation-doceng-2019_reviewed.pdf (1.04 Mo)
