Abstract : In recent years, there has been increasing awareness of the preservation, protection and sustainable use of natural resources. Water resources, being one of the most important, face major threats due to contamination by pollutants of various types and origins. Maintaining the quality of water resources requires more robust, reliable and more frequent monitoring than traditional data collection techniques based on manual sampling methods. This article, which is the result of ongoing research, proposes a practical and cost-effective solution for a surface water monitoring system, using a robotics platform and cloud services. The proposed solution allows for scalability and will accommodate a wide range of end-user specifications. To allow for continuous operation in longer activities, the design of a versatile real-time water quality monitoring system should also take into consideration the question of its energy requirements and self-sufficiency.
https://hal.inria.fr/hal-02295229 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, September 24, 2019 - 9:56:02 AM Last modification on : Tuesday, September 24, 2019 - 10:01:50 AM Long-term archiving on: : Sunday, February 9, 2020 - 4:57:51 PM
João Marques, Brígida Lopes, Carlos Ferreira, Henrique Pinho, Manuel Barros, et al.. Towards a Practical and Cost-Effective Water Monitoring System. 10th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), May 2019, Costa de Caparica, Portugal. pp.266-272, ⟨10.1007/978-3-030-17771-3_23⟩. ⟨hal-02295229⟩
