A research survey: review of AI solution strategies of job shop scheduling problem, J. Intell. Manuf, vol.26, issue.5, pp.961-973, 2015. ,
Design of reconfigurable manufacturing systems, J. Manuf. Syst, vol.29, issue.4, pp.130-141, 2010. ,
Smart Adaptable Assembly Systems, Procedia CIRP, vol.44, pp.4-13, 2016. ,
Reconfigurable Manufacturing Systems, CIRP Ann, vol.48, issue.2, pp.527-540, 1999. ,
Re-thinking diagnosis for future automation systems: An analysis of current diagnostic practices and their applicability in emerging IT based production paradigms, Comput. Ind, vol.62, issue.7, pp.639-659, 2011. ,
Construction of Intelligent Manufacturing Workshop Based on Lean Management, Procedia CIRP, vol.56, pp.599-603, 2016. ,
Service innovation and smart analytics for Industry 4.0 and big data environment, Procedia CIRP, vol.16, pp.3-8, 2014. ,
, , vol.3, pp.616-630, 2017.
Advanced manufacturing systems: socialization characteristics and trends, J. Intell. Manuf, vol.28, issue.5, pp.1079-1094, 2017. ,
Sustainable Living Factories for Next Generation Manufacturing, Procedia Manuf, vol.21, pp.26-36, 2018. ,
Multi-agent based approach for single machine scheduling with sequence-dependent setup times and machine maintenance, Appl. Soft Comput. J, vol.23, pp.165-179, 2014. ,
Smart manufacturing based on cyber-physical systems and beyond, J. Intell. Manuf, pp.1-13, 2017. ,
Scheduling flexible job-shops with transportation times: Mathematical models and a hybrid imperialist competitive algorithm, Appl. Math. Model, vol.41, pp.667-682, 2016. ,
A Survey of Recent Research on Optimization Models and Algorithms for Operations Management from the Process View, Sci. Program, vol.2017, 2017. ,
A bio-inspired mobile agent-based integrated system for flexible autonomic job shop scheduling, J. Manuf. Syst, vol.32, issue.4, pp.752-763, 2013. ,
A reinforcement learning approach to parameter estimation in dynamic job shop scheduling, Comput. Ind. Eng, vol.110, pp.75-82, 2017. ,
The 'Internet of Things' enabled real-time scheduling for remanufacturing of automobile engines, J. Clean. Prod, vol.185, pp.562-575, 2018. ,
Single-machine-based joint optimization of predictive maintenance planning and production scheduling, Robot. Comput. Integr. Manuf, vol.51, pp.238-247, 2018. ,
Solving the flexible job shop scheduling problem with sequence-dependent setup times, Eur. J. Oper. Res, vol.265, issue.2, pp.503-516, 2018. ,
URL : https://hal.archives-ouvertes.fr/emse-01792233
A genetic algorithm embedded with a concise chromosome representation for distributed and flexible jobshop scheduling problems, J. Intell. Manuf, vol.29, issue.1, pp.19-34, 2018. ,
Optimisation of distributed manufacturing flexible job shop scheduling by using hybrid genetic algorithms, J. Intell. Manuf, vol.28, issue.8, pp.1973-1986, 2017. ,
A Petri net-based particle swarm optimization approach for scheduling deadlock-prone flexible manufacturing systems, J. Intell. Manuf, vol.29, issue.5, pp.1083-1096, 2015. ,
Dynamic Agent-based Bi-objective Robustness for Tardiness and Energy in a Dynamic Flexible Job Shop, Procedia CIRP, vol.57, pp.728-733, 2016. ,
Integration of process planning and scheduling using chaotic particle swarm optimization algorithm, Expert Syst. Appl, vol.64, pp.569-588, 2016. ,
Integration of genetic algorithm and Gantt chart for job shop scheduling in distributed manufacturing systems, Comput. Ind. Eng, vol.53, issue.2, pp.313-320, 2007. ,
Optimizing the sum of maximum earliness and tardiness of the job shop scheduling problem, Comput. Ind. Eng, vol.107, pp.12-24, 2017. ,
The job shop scheduling problem with convex costs, Eur. J. Oper. Res, vol.268, issue.1, pp.82-100, 2018. ,
A study on local search neighborhoods for the job shop scheduling problem with total weighted tardiness objective, Comput. Oper. Res, vol.66, pp.44-57, 2016. ,
A hybrid genetic algorithm with two-stage dispatching heuristic for a machine scheduling problem with step-deteriorating jobs and ratemodifying activities, Comput. Ind. Eng, vol.98, pp.113-124, 2016. ,
Cloud manufacturing -Scheduling as a service for sheet metal manufacturing, Comput. Oper. Res, vol.0, pp.1-12, 2018. ,
JIT-scheduling in unrelated parallel-machine environment with aging effect and multi-maintenance activities, Int. J. Serv. Oper. Manag, vol.18, issue.1, p.99, 2014. ,
A hybrid genetic algorithm and tabu search for a multiobjective dynamic job shop scheduling problem, Int. J. Prod. Res, vol.51, issue.12, pp.3516-3531, 2013. ,
Dynamic scheduling of shared human-robot manufacturing operations, Procedia CIRP, vol.72, pp.9-14, 2018. ,
A simulation-based study of dispatching rules in a dynamic job shop scheduling problem with batch release and extended technical precedence constraints, Eur. J. Oper. Res, vol.257, issue.1, pp.13-24, 2017. ,
A genetic algorithm-based scheduler for multiproduct parallel machine sheet metal job shop, Expert Syst. Appl, vol.38, issue.7, pp.8703-8715, 2011. ,
Scheduling in aerospace composite manufacturing systems: a two-stage hybrid flow shop problem, Int. J. Adv. Manuf. Technol, vol.95, issue.9, pp.3259-3274, 2018. ,
, Flexible Job-Shop Rescheduling for New Job Insertion by Using Discrete Jaya Algorithm, pp.1-12, 2018.
Hybrid heuristic search approach for deadlockfree scheduling of flexible manufacturing systems using Petri nets, Appl. Soft Comput, vol.18, issue.2, pp.240-245, 2017. ,
