Uninterruptible Power Supply System Utilizing Electric Double-Layer Capacitors, Power Conversion Conference, pp.2-5 ,
Overview of current and future energy storage technologies for electric power applications, Renewable and Sustainable Energy Reviews, vol.13, pp.1513-1522, 2009. ,
Predictive Optimal Matrix Converter Control for a Dynamic Voltage Restorer with Flywheel Energy Storage, IECON09-35th Annual Conference of IEEE, pp.3-5, 2009. ,
Electric power converter, vol.3867643, 1975. ,
A new-neutral-pointclamped PWM inverter, IEEE Trans. Ind. Applicat, issue.5, pp.518-523, 1981. ,
Multilevel inverters: a survey of topologies, controls, and applications, IEEE Trans. Ind. Electron, vol.49, issue.4, pp.724-738, 2002. ,
An innovative modular multilevel converter topology suitable for a wide power range, IEEE Bologna Power Tech Conference Proceedings, pp.23-26 ,
Chapter 31: Multilevel power converters, 2006. ,
Fault-tolerant design for a threelevel neutral-point-clamped multilevel inverter topology, EUROCON-International Conference on Computer as a Tool (EUROCON), pp.1-4, 2011. ,
Generalized State-Space Modelling for m Level Diode-Clamped Multilevel Converters, International Symposium on Mathematical Methods in Engineering, MME10 Coimbra, pp.149-156, 2010. ,
HVDC transmission systems: Bipolar back-to-back diode clamped multilevel converter with fast optimumpredictive control and capacitor balancing strategy, vol.81, pp.1436-1445, 2011. ,
Multilevel High Voltage Pulse Generation Based on a New Modular Solid State Switch, Plasma Science, IEEE Transactions on, vol.42, 2014. ,
Seven Levels Unipolar/Bipolar Pulsed Power Generator, Plasma Science, IEEE Transactions on, vol.44, 2016. ,
The age of multilevel converters arrives, IEEE Ind. Electron. Magazine, vol.2, issue.2, pp.28-39, 2008. ,
Generalized Solid-state Marx Modulator Topology, IEEE Transactions on Dielectrics and Electrical Insulation, vol.16, pp.1037-1042, 2009. ,
Solid-State Marx Type Circuit for ISOLDE Voltage Target Modulator, 2009 IET European Pulsed Power Conference, pp.21-25, 2009. ,
Power supply with bipolar pulsed output voltage and high repetition rate based on a solid state Marx topology, pp.1377-1381, 2011. ,
All-Solid-State Pulse Adder with Bipolar High Voltage Fast Narrow Pulses Output, IEEE Transactions on Dielectrics and Electrical Insulation, vol.18, issue.3, pp.775-782, 2011. ,
A Repetitive Solid State Marx-Type Pulsed Power Generator Using Multistage Switch-Capacitor Cells, IEEE Transactions on Plasma Science, vol.40, issue.10, pp.2316-2321, 2012. ,
Marx type solid-state bipolar modulator topologies: performance comparison, IEEE Transaction on Plasma Science, vol.40, pp.2603-2610, 2012. ,
Solid-State Bipolar Marx Modulator Modeling, IEEE Transaction on Plasma Science, vol.42, pp.3048-3056, 2014. ,
Uninterruptible Power Supplies and Active Filters, p.9780849330353, 2004. ,
Instantaneous Power Theory and Applications to Power Conditioning, 2007. ,
An instantaneous active and reactive current component method for active filters, IEEE Trans. Power Electron, vol.15, issue.4, pp.660-669, 2000. ,
