Lagrangian chaos, Eulerian chaos, and mixing enhancement in converging-diverging channel flows, Physics of Fluids, vol.8, pp.1192-1206, 1996. ,
Lagrangian coherent structures, Annual Review of Fluid Mechanics, vol.47, 2015. ,
Lagrangian-based methods for coherent structure detection, Chaos: An Interdisciplinary Journal of Nonlinear Science, vol.25, p.97617, 2015. ,
The dynamics of enstrophy transfer in two-dimensional hydrodynamics, Physica D, vol.48, pp.273-294, 1991. ,
Chaotic transport and mixing by ocean gyre circulation, Stochastic Modelling in Physical Oceanography, pp.439-466, 1996. ,
Lagrangian coherent structures and mixing in two-dimensional turbulence, Physica D: Nonlinear Phenomena, vol.147, 2000. ,
Lagrangian coherent structures from approximate velocity data, Physics of Fluids, vol.14, pp.1851-1861, 2002. ,
Definition and properties of Lagrangian coherent structures from finite-time Lyapunov exponents in two-dimensional, Physica D, vol.212, pp.271-304, 2005. ,
Experimental measurements of stretching fields in fluid mixing, Phys. Rev. Lett, vol.88, p.254501, 2002. ,
Uncovering the Lagrangian skeleton of turbulence, Phys. Rev. Lett, vol.98, p.144502, 2007. ,
Lagrangian feature extraction of the cylinder wake, Physics of Fluids, vol.22, p.91108, 2010. ,
The computation of finite-time Lyapunov exponents on unstructured meshes and for non-euclidean manifolds, Chaos, vol.20, p.17505, 2010. ,
A variational theory of hyperbolic Lagrangian coherent structures, Physica D, vol.240, pp.574-598, 2011. ,
Computing Lagrangian coherent structures from their variational theory, Chaos, vol.22, p.13128, 2012. ,
Geodesic theory of transport barriers in two-dimensional flows, Physica D: Nonlinear Phenomena, vol.241, pp.1680-1702, 2012. ,
Geometry of the ergodic quotient reveals coherent structures in flows, Physica D: Nonlinear Phenomena, vol.241, pp.1255-1269, 2012. ,
Analysis of fluid flows via spectral properties of the Koopman operator, Annual Review of Fluid Mechanics, vol.45, pp.357-378, 2013. ,
Almost-invariant and finite-time coherent sets: Directionality, duration, and diffusion, Ergodic Theory, Open Dynamics, and Coherent Structures, pp.171-216, 2014. ,
Braids of entangled particle trajectories, Chaos, vol.20, p.17516, 2010. ,
Jean leray and algebraic topology, Selected Papers -Oeuvres Scientifiques, vol.1, 1998. ,
Sur la géométrie differérentielle des groupes de lie de dimension infinie et ses applications à l'hydrodynamique des fluides parfaits, Ann. Inst. Fourier, vol.16, pp.319-361, 1966. ,
Measuring topological chaos, Phys. Rev. Lett, vol.94, p.84502, 2005. ,
Theory of braids, Ann. of Math, vol.48, pp.101-126, 1947. ,
Detecting coherent structures using braids, Physica D: Nonlinear Phenomena, vol.241, pp.95-105, 2012. ,
BRAIDLAB: a software package for braids and loops, 2015. ,
Finite-time braiding exponents, Chaos: An Interdisciplinary Journal of Nonlinear Science, vol.25, p.87407, 2015. ,
Braid entropy of two-dimensional turbulence, Sci. Rep, vol.5, p.18564, 2015. ,
Stirring by chaotic advection, J. Fluid Mech, vol.143, pp.1-21, 1984. ,
Topological methods in surface dynamics, Topology Appl, vol.58, pp.223-298, 1994. ,
, A Primer on Mapping Class Groups, vol.49, 2012.
A combinatorial approach to reducibility of mapping classes, Mapping Class Groups and Moduli Spaces of Riemann Surfaces, vol.150, pp.1-31, 1993. ,
Braids and the nielsen-thurston classification, J. Knot Theory Ramifications, vol.4, 1995. ,
Braids: A survey, Handbook of Knot Theory, 2005. ,
Über zopfgruppen und gleichsinnig verdrillte verkettungen, Abhandlungen aus dem Mathematischen Seminar der Universität Hamburg, vol.11, pp.179-186, 1935. ,
The Burau representation is not faithful for n ? 6, Topology, vol.32, pp.439-447, 1993. ,
The Burau representation is not faithful for n = 5, Geometry & Topology, vol.3, pp.397-404, 1999. ,
Infinite generation of the kernels of the Magnus and Burau representations, Algebraic & Geometric Topology, vol.10, pp.837-851, 2010. ,
The Burau estimate for the entropy of a braid, Algebraic & Geometric Topology, vol.7, pp.1345-1378, 2007. ,
The Burau representation is unitary, Proc. Amer. Math. Soc, vol.90, pp.199-202, 1984. ,
The nth root of a braid is unique up to conjugacy, Algebraic & Geometric Topology, vol.3, pp.1103-1118, 2003. ,
Accelerating computation of eigenvectors in the dense nonsymmetric eigenvalue problem, High Performance Computing for Computational Science, pp.182-191, 2015. ,
FEAST eigensolver for non-Hermitian problems, 2015. ,
, Algorithmic geometry, 1998.
The kinematics of mixing: stretching, chaos, and transport, 1989. ,
Chaos in deterministic systems: strange attractors, turbulence, and applications in chemical engineering, Chemical Engineering Science, vol.43, pp.139-183, 1988. ,
The Lawrence-Krammer representation, Topology and geometry of manifolds (Proc. Sympos. Pure Math.), vol.71, 2003. ,
Computation of matrix chain products. part I, SIAM Journal on Computing, vol.11, pp.362-373, 1982. ,
Computation of matrix chain products. part II, SIAM J. Comput, vol.13, pp.228-251, 1984. ,
