Adaptive foveated single-pixel imaging with dynamic supersampling, Science Advances, vol.3, issue.4, 2017. ,
Comparative study of sampling strategies for sparse photon multispectral lidar imaging: towards mosaic filter arrays, Journal of Optics, vol.19, issue.9, p.94006, 2017. ,
Firstphoton imaging, Science, vol.343, issue.6166, pp.58-61, 2014. ,
A few photons among many: Unmixing signal and noise for photon-efficient active imaging, IEEE Trans. Comput. Imaging, vol.3, issue.3, pp.445-459, 2017. ,
Bayesian 3d reconstruction of complex scenes from single-photon lidar data, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-02185077
Proximal-gradient methods for poisson image reconstruction with bm3d-based regularization, 2017 IEEE 7th International Workshop on Computational Advances in Multi-Sensor Adaptive Processing, pp.183-187, 2017. ,
Robust restoration of sparse multidimensional single-photon LiDAR images, IEEE Trans. Comput. Imaging, 2019. ,
Singlephoton 3d imaging with deep sensor fusion, ACM Trans. Graph, vol.37, issue.4, p.12, 2018. ,
Single-pixel imaging via compressive sampling, IEEE Signal Processing Magazine, vol.25, issue.2, pp.83-91, 2008. ,
A framework for dynamic image sampling based on supervised learning, IEEE Trans. Comput. Imaging, vol.4, issue.1, pp.1-16, 2018. ,
Lidar waveform based analysis of depth images constructed using sparse single photon data, IEEE Trans. Image Process, vol.25, issue.5, pp.1935-1946, 2015. ,
Restoration of intensity and depth images constructed using sparse singlephoton data, Proc. EUSIPCO, pp.86-90, 2016. ,
Spectral unmixing of multispectral lidar signals, IEEE Trans. Signal Process, vol.63, issue.20, pp.5525-5534, 2015. ,
Single-photon three-dimensional imaging at up to 10 kilometers range, Opt. Express, vol.25, issue.10, pp.11-919, 2017. ,
Real-time 3d reconstruction of complex scenes using single-photon lidar: when image processing meets computer graphics, 2019. ,
Monte Carlo Statistical Methods, 1999. ,
Handbook of Markov chain Monte Carlo. ser. Chapman & Hall/CRC Handbooks of Modern Statistical Methods, 2011. ,
Kilometer-range depth imaging at 1550 nm wavelength using an InGaAs/InP single-photon avalanche diode detector, Opt. Express, vol.21, issue.19, pp.22-098, 2013. ,
Sparkling: variable-density k-space filling curves for accelerated t2*-weighted mri, Magnetic Resonance in Medicine, vol.81, issue.6, pp.3643-3661, 2019. ,
