A spectral graph uncertainty principle, IEEE Trans. Info. Theory, vol.59, issue.7, pp.4338-4356, 2013. ,
Efficient sampling set selection for bandlimited graph signals using graph spectral proxies, IEEE Transactions on Signal Processing, vol.64, issue.14, pp.3775-3789, 2016. ,
Efficient Sampling Set Selection for Bandlimited Graph Signals Using Graph Spectral Proxies, IEEE Transactions on Signal Processing, vol.64, issue.14, pp.3775-3789, 2016. ,
Intertwining wavelets or multiresolution analysis on graphs through random forests, Applied and Computational Harmonic Analysis, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01877023
Network distance based on laplacian flows on graphs, 2018. ,
Dynamical processes on complex networks, 2008. ,
A unified deep learning formalism for processing graph signals, 2019. ,
Geometric deep learning: Going beyond euclidean data, IEEE Signal Process. Mag, vol.34, issue.4, pp.18-42, 2017. ,
Greedy Sampling of Graph Signals, IEEE Trans. Signal Processing, vol.66, issue.1, pp.34-47, 2018. ,
, Discrete Signal Processing on Graphs: Sampling Theory. CoRR, 2015.
Graph spectral image processing, Proceedings of the IEEE, vol.106, issue.5, pp.907-930, 2018. ,
Laplacians and the cheeger inequality for directed graphs, Annals of Combinatorics, vol.9, issue.1, pp.1-19, 2005. ,
, Spectral graph theory. Number 92, 1997.
Time-Frequency Analysis, 1995. ,
Diffusion wavelets, Applied and Computational Harmonic Analysis, vol.21, issue.1, pp.53-94, 2006. ,
Ten lectures on wavelets, 1992. ,
, Sampling and Recovery of Graph Signals, 2017.
, Cooperative and Graph Signal Processing, 2018.
Learning laplacian matrix in smooth graph signal representations, IEEE Trans. Signal Processing, vol.64, issue.23, pp.6160-6173, 2016. ,
50 years of data science, Journal of Computational and Graphical Statistics, vol.26, issue.4, pp.745-766, 2017. ,
Uncertainty principles and signal recovery, SIAM Journal on Applied Mathematics, vol.49, issue.3, pp.906-931, 1989. ,
Spectral anomaly detection using graph-based filtering for wireless sensor networks, IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.1085-1089, 2014. ,
Graph learning from data under laplacian and structural constraints, J. Sel. Topics Signal Processing, vol.11, issue.6, pp.825-841, 2017. ,
Time-Frequency / Time-Scale Analysis, 1999. ,
, Explorations in Time-Frequency Analysis, 2018.
Théorie analytique de la chaleur, Chez Firmin Didot, p.1822 ,
Convolutional neural network architectures for signals supported on graphs, IEEE Trans. Signal Processing, vol.67, issue.4, pp.1034-1049, 2019. ,
Translation on graphs : An isometric shift operator, IEEE Signal Processing Letters, vol.22, issue.12, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01221562
Semi-supervised learning for graph to signal mapping: A graph signal wiener filter interpretation, IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.1115-1119, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00942695
Discrete Calculus: Applied Analysis on Graphs for Computational Science, 2010. ,
A time-vertex signal processing framework: Scalable processing and meaningful representations for time-series on graphs, IEEE Transactions on Signal Processing, vol.66, issue.3, pp.817-829, 2018. ,
Neighborhood-preserving translations on graphs, IEEE GlobalSIP, pp.410-414, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01511073
Graph diffusion distance: A difference measure for weighted graphs based on the graph laplacian exponential kernel, IEEE GlobalSIP, pp.419-422, 2013. ,
Wavelets on graphs via spectral graph theory, Applied and Computational Harmonic Analysis, vol.30, issue.2, pp.129-150, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00541855
The empirical mode decomposition and the Hilbert spectrum for nonlinear and non-stationary time series analysis, Proceedings of the Royal Society of London. Series A: Mathematical, Physical and Engineering Sciences, vol.454, pp.903-995, 1971. ,
Hierarchical graph laplacian eigen transforms, JSIAM Letters, vol.6, pp.21-24, 2014. ,
Autoregressive Moving Average Graph Filtering, IEEE Transactions on Signal Processing, vol.65, issue.2, pp.274-288, 2017. ,
Statistical Analysis of Network Data: Methods and Models, 2009. ,
Diffusion kernels on graphs and other discrete input spaces, International Conference on Machine Learning, pp.315-322, 2002. ,
Approximate fast graph fourier transforms via multilayer sparse approximations, IEEE Transactions on Signal and Information Processing over Networks, vol.4, issue.2, pp.407-420, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01416110
Deep learning, Nature, vol.521, issue.7553, pp.436-444, 2015. ,
, Image Processing and Analysis with Graphs. Theory and Practice, 2012.
URL : https://hal.archives-ouvertes.fr/hal-00813324
Autoregressive moving average graph filter design, 6th Joint WIC/IEEE Symposium on Information Theory and Signal Processing in the Benelux, 2016. ,
Spectrally approximating large graphs with smaller graphs. Arxviv ; CoRR, 2018. ,
A Wavelet tour of signal processing, 1999. ,
Connecting the dots: Identifying network structure via graph signal processing, IEEE Signal Process. Mag, vol.36, issue.3, pp.16-43, 2019. ,
Perfect reconstruction two-channel wavelet filter banks for graph structured data, IEEE Transactions on Signal Processing, vol.60, issue.6, pp.2786-2799, 2012. ,
Compact support biorthogonal wavelet filterbanks for arbitrary undirected graphs, IEEE Transactions on Signal Processing, vol.61, issue.19, pp.4673-4685, 2013. ,
Networks: an introduction, 2010. ,
Graph signal processing: Overview, challenges, and applications, Proceedings of the IEEE, vol.106, pp.808-828, 2018. ,
Characterization and inference of graph diffusion processes from observations of stationary signals, IEEE Trans. Signal and Information Processing over Networks, vol.4, issue.3, pp.481-496, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01875916
Global and local uncertainty principles for signals on graphs, APSIPA Transactions on Signal and Information Processing, vol.7, 2018. ,
Random sampling of bandlimited signals on graphs, Applied and Computational Harmonic Analysis, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01229578
Refined support and entropic uncertainty inequalities, IEEE Transactions on Information Theory, vol.59, issue.7, pp.4272-4279, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00746976
A survey of uncertainty principles and some signal processing applications, Advances in Computational Mathematics, vol.40, issue.3, pp.629-650, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00757450
Eigendecomposition-Free Sampling Set Selection for Graph Signals, 2018. ,
Discrete signal processing on graphs, IEEE Transactions on Signal Processing, vol.61, issue.7, pp.1644-1656, 2013. ,
On the graph fourier transform for directed graphs, IEEE Journal of Selected Topics in Signal Processing, vol.11, issue.6, pp.796-811, 2017. ,
Network topology inference from spectral templates, IEEE Trans. Signal and Information Processing over Networks, vol.3, issue.3, pp.467-483, 2017. ,
, Harmonic analysis on directed graphs and applications: from fourier analysis to wavelets, 2018.
URL : https://hal.archives-ouvertes.fr/tel-02024654
A digraph fourier transform with spread frequency components, 2017. ,
A multiscale pyramid transform for graph signals, IEEE Transactions on Signal Processing, vol.64, issue.8, pp.2119-2134, 2016. ,
The emerging field of signal processing on graphs: Extending high-dimensional data analysis to networks and other irregular domains, IEEE Signal Processing Magazine, vol.30, issue.3, pp.83-98, 2013. ,
Vertex-frequency analysis on graphs, Applied and Computational Harmonic Analysis, vol.40, issue.2, pp.260-291, 2016. ,
Chebyshev polynomial approximation for distributed signal processing, International Conference DCOSS, pp.1-8, 2011. ,
Vertex-Frequency Analysis of Graph Signals, 2019. ,
The discrete cosine transform, SIAM review, vol.41, issue.1, pp.135-147, 1999. ,
Learning heat diffusion graphs, IEEE Trans. Signal and Information Processing over Networks, vol.3, issue.3, pp.484-499, 2017. ,
Learning parametric dictionaries for signals on graphs, IEEE Transactions on Signal Processing, vol.62, issue.15, pp.3849-3862, 2014. ,
Graph sampling with determinantal processes, 25th European Signal Processing Conference (EUSIPCO), pp.1674-1678, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01483347
Graph wavelets for multiscale community mining, IEEE Trans. Signal Processing, vol.62, issue.20, pp.5227-5239, 2014. ,
Subgraph-Based Filterbanks for Graph Signals, IEEE Transactions on Signal Processing, vol.64, issue.15, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01243889
Graph empirical mode decomposition, European Signal Processing Conference (EUSIPCO), pp.2350-2354, 2014. ,
Design of graph filters and filterbanks, Cooperative and Graph Signal Processing, pp.299-324, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01675375
Approximating spectral clustering via sampling: a review. CoRR, abs, 1901. ,
Compressive spectral clustering, International Conference on Machine Learning, pp.1002-1011, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01320214
NetLSD: Hearing the shape of a graph, ACM SIGKDD International Conference on Knowledge Discovery & Data Mining, pp.2347-2356, 2018. ,
Signals on Graphs: Uncertainty Principle and Sampling, IEEE Transactions on Signal Processing, vol.64, issue.18, pp.4845-4860, 2016. ,
The future of data analysis, Ann. Math. Statist, vol.33, issue.1, pp.1-67, 1962. ,
A tutorial on spectral clustering, Statistics and computing, vol.17, issue.4, pp.395-416, 2007. ,
Learning of structured graph dictionaries, IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.3373-3376, 2012. ,
Graph neural networks: A review of methods and applications, 2018. ,
Graph spectral compressed sensing for sensor networks, IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.2865-2868, 2012. ,
