A kilobit special number field sieve factorization, ASIACRYPT 2007, vol.4833, pp.1-12, 2007. ,
Pairings are not dead, just resting, slides at ECC 2017 workshop, 2017. ,
Implementing pairings at the 192-bit security level, PAIRING 2012, vol.7708, pp.177-195, 2013. ,
RELIC is an Efficient LIbrary for Cryptography ,
Faster explicit formulas for computing pairings over ordinary curves, EUROCRYPT 2011, vol.6632, pp.48-68, 2011. ,
Factorization of RSA-220, ?A2=NMBRTHRY;d17fe291.1605, 2016. ,
Updating key size estimations for pairings, Journal of Cryptology, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01534101
Improving NFS for the discrete logarithm problem in non-prime finite fields, EUROCRYPT 2015, Part I. LNCS, vol.9056, pp.129-155, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01112879
The tower number field sieve, ASIACRYPT 2015, Part II. LNCS, vol.9453, pp.31-55, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01155635
Subgroup security in pairing-based cryptography, LATINCRYPT 2015, vol.9230, pp.245-265, 2015. ,
From extractable collision resistance to succinct non-interactive arguments of knowledge, and back again, ITCS 2012, pp.326-349, 2012. ,
Identity-based encryption from the Weil pairing, CRYPTO 2001, vol.2139, pp.213-229, 2001. ,
Short signatures from the Weil pairing, ASIACRYPT 2001, vol.2248, pp.514-532, 2001. ,
Discrete logarithms in GF(p) -180 digits, Number Theory list, item 004703, 2014. ,
, New zk-SNARK elliptic curve construction. Zcash blog, pp.12-381, 2017.
On instantiating pairing-based protocols with elliptic curves of embedding degree one, IEEE Trans. Computers, vol.66, issue.6, pp.1061-1070, 2017. ,
Factorization of a 1061-bit number by the special number field sieve. Cryptology ePrint Archive, vol.444, 2012. ,
Pairing-friendly twisted hessian curves, LNCS, vol.11356, pp.228-247 ,
URL : https://hal.archives-ouvertes.fr/hal-01934160
Asymmetric squaring formulae, 18th IEEE Symposium on Computer Arithmetic (ARITH '07), pp.113-122, 2007. ,
Efficient elliptic curve exponentiation using mixed coordinates, ASIACRYPT'98, vol.1514, pp.51-65 ,
, , 1998.
Faster pairing computations on curves with high-degree twists, PKC 2010, vol.6056, pp.224-242, 2010. ,
Multiplication and squaring on pairing-friendly fields, Cryptology ePrint Archive, issue.471, 2006. ,
Efficient computation of pairings on jacobi quartic elliptic curves, J. Mathematical Cryptology, vol.8, issue.4, pp.331-362, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01095359
TNFS resistant families of pairing-friendly elliptic curves, 1017. ,
Optimal TNFS-secure pairings on elliptic curves with even embedding degree. Cryptology ePrint Archive, 2018. ,
A taxonomy of pairing-friendly elliptic curves, Journal of Cryptology, vol.23, issue.2, pp.224-280, 2010. ,
A kilobit hidden SNFS discrete logarithm computation, Part I. LNCS, vol.10210, pp.202-231, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01376934
Designing and detecting trapdoors for discrete log cryptosystems, CRYPTO'92, vol.740, pp.66-75, 1993. ,
Faster squaring in the cyclotomic subgroup of sixth degree extensions, PKC 2010, vol.6056, pp.209-223, 2010. ,
Simulating DL computation in GF(p n ) with the new variants of the Tower-NFS algorithm to deduce security level estimates, 2017. ,
A one round protocol for tripartite Diffie-Hellman, Journal of Cryptology, vol.17, issue.4, pp.263-276, 2004. ,
Improvements to the general number field sieve for discrete logarithms in prime fields. A comparison with the Gaussian integer method, Math. Comp, vol.72, issue.242, pp.953-967, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-01102016
The special number field sieve in Fpn -application to pairing-friendly constructions, PAIRING 2013, vol.8365, pp.45-61, 2014. ,
Squaring in cyclotomic subgroups, Math. Comput, vol.82, issue.281, pp.555-579, 2013. ,
Efficient optimal ate pairing at 128-bit security level, INDOCRYPT 2017, vol.10698, pp.186-205, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01620848
Extended tower number field sieve: A new complexity for the medium prime case, CRYPTO 2016, Part I. LNCS, vol.9814, pp.543-571, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01281966
Secure and efficient pairing at 256-bit security level, ACNS 17, vol.10355, pp.59-79, 2017. ,
Factorization of a 768-bit RSA modulus, CRYPTO 2010, vol.6223, pp.333-350, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00444693
Computation of a 768-bit prime field discrete logarithm, Part I. LNCS, vol.10210, pp.185-201, 2017. ,
Tools for simulating features of composite order bilinear groups in the prime order setting, EUROCRYPT 2012, vol.7237, pp.318-335, 2012. ,
Pairing computation on edwards curves with highdegree twists, Inscrypt, Revised Selected Papers, vol.8567, pp.185-200, 2013. ,
Challenges with assessing the impact of NFS advances on the security of pairing-based cryptography, Mycrypt Conference, Revised Selected Papers, vol.10311, pp.83-108 ,
, , 2016.
Five, six, and seven-term Karatsuba-like formulae, IEEE Transactions on Computers, vol.54, pp.362-369, 2005. ,
, Recommendation key management (part 1: General), 2016.
A family of implementation-friendly BN elliptic curves, Journal of Systems and Software, vol.84, issue.8, pp.1319-1326, 2011. ,
A general polynomial selection method and new asymptotic complexities for the tower number field sieve algorithm, ASIACRYPT 2016, Part I. LNCS, vol.10031, pp.37-62, 2016. ,
The number field sieve for integers of low weight, Math. Comp, vol.79, issue.269, pp.583-602, 2010. ,
Implementing cryptographic pairings, PAIRING 2007, vol.4575, pp.177-196, 2007. ,
Special prime numbers and discrete logs in finite prime fields, Math. Comp, vol.71, issue.737, pp.363-377, 2002. ,
Accelerating the CM method, LMS Journal of Computation and Mathematics, vol.15, pp.172-204, 2012. ,
Constructing pairing-friendly elliptic curves using factorization of cyclotomic polynomials, PAIRING 2008, vol.5209, pp.136-145, 2008. ,
Optimal pairings, IEEE Transactions on Information Theory, vol.56, issue.1, pp.455-461, 2010. ,
