Algorithms for Sparse Random 3XOR: The Low-Density Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We present algorithms for variants of the 3XOR problem with lists consisting of random sparse $n$-bit vectors. We consider two notions of sparsity: low-density (each bit is independently biased towards zero) and low-weight (the Hamming weight of $n$-bit vectors is fixed). We show that the random sparse 3XOR problem can be solved in strongly subquadratic time, namely less than $\bigO{N^{2-\epsilon}}$ operations for a constant $\epsilon > 0$. This stands in strong contrast with the regular case, where it has not been possible to have the exponent drop below $2 - o(1)$. In the low-density setting, a very simple algorithm even runs in linear time with overwhelming success probability when the density is less than $0.0957$. Our algorithms exploit the randomness (and sparsity) of the input in an essential way.
main1.pdf (655.9 Ko) Télécharger le fichier
hal-02306917 , version 1 (07-10-2019)
hal-02306917 , version 2 (12-05-2020)
hal-02306917 , version 3 (01-03-2021)
hal-02306917 , version 4 (02-10-2021)
  • HAL Id : hal-02306917 , version 4
Charles Bouillaguet, Claire Delaplace, Antoine Joux. Algorithms for Sparse Random 3XOR: The Low-Density Case. 2021. ⟨hal-02306917v4⟩
267 Consultations
277 Téléchargements
