Fast Diameter Computation within Split Graphs
When can we compute the diameter of a graph in quasi linear time?
We address this question for the class of {\em split graphs}, that we observe to be the hardest instances for deciding whether the diameter is at most two.
We stress that although the diameter of a non-complete split graph can only be either $2$ or $3$, under the Strong Exponential-Time Hypothesis (SETH) we cannot compute the diameter of an $n$-vertex $m$-edge split graph in less than quadratic time -- in the size $n+m$ of the input.
Therefore it is worth to study the complexity of diameter computation on {\em subclasses} of split graphs, in order to better understand the complexity border.
Specifically, we consider the split graphs with bounded {\em clique-interval number} and their complements, with the former being a natural variation of the concept of interval number for split graphs that we introduce in this paper.
We first discuss the relations between the clique-interval number and other graph invariants such as the classic interval number of graphs, the treewidth, the {\em VC-dimension} and the {\em stabbing number} of a related hypergraph.
Then, in part based on these above relations, we almost completely settle the complexity of diameter computation on these subclasses of split graphs:
- For the $k$-clique-interval split graphs, we can compute their diameter in truly subquadratic time if $k={\cal O}(1)$, and even in quasi linear time if $k=o(\log{n})$ and in addition a corresponding ordering of the vertices in the clique is given. However, under SETH this cannot be done in truly subquadratic time for any $k = \omega(\log{n})$.
- For the {\em complements} of $k$-clique-interval split graphs, we can compute their diameter in truly subquadratic time if $k={\cal O}(1)$, and even in time ${\cal O}(km)$ if a corresponding ordering of the vertices in the stable set is given. Again this latter result is optimal under SETH up to polylogarithmic factors.
Our findings raise the question whether a $k$-clique interval ordering can always be computed in quasi linear time.
We prove that it is the case for $k=1$ and for some subclasses such as bounded-treewidth split graphs, threshold graphs and comparability split graphs.
Finally, we prove that some important subclasses of split graphs -- including the ones mentioned above -- have a bounded clique-interval number.
