Camino: 634 Open-Source Diffusion-MRI Reconstruction and Processing, Proc. Intl. Soc. Magn. Reson, 2005. ,
, , 2014.
, Machine learning for neuroimaging with scikit-learn
A fast diffeomorphic image registration algorithm, NeuroImage, vol.38, pp.95-113, 2007. ,
SPM: A history. Neuroimage 62-248, 2012. ,
Unified segmentation, NeuroImage, vol.26, pp.839-851, 2005. ,
Symmetric diffeomorphic image 646 registration with cross-correlation: Evaluating automated labeling of elderly and 647 neurodegenerative brain, Medical Image Analysis, vol.12, pp.26-41, 2008. ,
The Insight 649 ToolKit image registration framework, Front Neuroinform, vol.8, 2014. ,
, , 2019.
BrainVISA: Software 653 platform for visualization and analysis of multi-modality brain data, NeuroImage, vol.13, pp.91441-91448, 2001. ,
AFNI: software for analysis and visualization of functional magnetic resonance 656 neuroimages, Comput. Biomed. Res, vol.29, pp.162-173, 1996. ,
Spatial and Anatomical Regularization of SVM: A General 659 Framework for Neuroimaging Data, IEEE Trans Pattern Anal Mach Intell, vol.35, pp.682-696, 2013. ,
An 662 automated labeling system for subdividing the human cerebral cortex on MRI scans into gyral 663 based regions of interest, NeuroImage, vol.31, pp.968-980, 2006. ,
Automatic parcellation of human cortical 665 gyri and sulci using standard anatomical nomenclature, Neuroimage, vol.53, pp.1-15, 2010. ,
668 fMRIPrep: a robust preprocessing pipeline for functional MRI, Nat Methods, vol.16, pp.111-116, 2019. ,
FreeSurfer, NeuroImage, vol.62, pp.774-781, 2012. ,
Measuring the thickness of the human cerebral cortex from 672 magnetic resonance images, PNAS, vol.97, pp.11050-11055, 2000. ,
Whole Brain 674 Segmentation: Automated Labeling of Neuroanatomical Structures in the Human Brain, 2002. ,
, Neuron, vol.33, pp.341-355
, , 2004.
, Sequence-independent segmentation of magnetic resonance images, NeuroImage, vol.23
Cortical Surface-Based Analysis: II: Inflation, 680 Flattening, and a Surface-Based Coordinate System, NeuroImage, vol.9, pp.195-207, 1999. ,
, , 2004.
, Automatically Parcellating the Human Cerebral Cortex. Cerebral Cortex, vol.14
Advanced 686 lesion symptom mapping analyses and implementation as BCBtoolkit, 2018. ,
Human Brain 689 Function, 1997. ,
Statistical Parametric 692 Mapping, 2007. ,
Characterizing Dynamic Brain 694 Responses with fMRI: A Multivariate Approach, NeuroImage, vol.2, pp.166-172, 1995. ,
, , 2014.
, Dipy, a library for the analysis of diffusion MRI data
, , 2017.
, Boutiques: a flexible framework for automated application integration in computing platforms, vol.701, 2018.
, , 2011.
Lightweight and Extensible Neuroimaging Data Processing Framework in 705 Python, Front. Neuroinform, vol.5 ,
BIDS apps: Improving ease of use, accessibility, and reproducibility of neuroimaging 708 data analysis methods, PLOS Computational Biology, vol.13, 2017. ,
The 711 brain imaging data structure, a format for organizing and describing outputs of neuroimaging 712 experiments, Scientific Data, vol.3, p.160044, 2016. ,
Automatic segmentation of brain MRIs of 2-year-olds into 83 regions of interest, p.714, 2008. ,
, NeuroImage, vol.40, pp.672-684
Open is Not Enough. Let's Take the Next Step: An 717 Integrated, Community-Driven Computing Platform for, Neuroscience. Front. Neuroinform. 6, vol.718, 2012. ,
Three-720 dimensional maximum probability atlas of the human brain, with particular reference to the 721 temporal lobe, Human Brain Mapping, vol.19, pp.224-247, 2003. ,
The slice-timing problem in 723 event-related fMRI, NeuroImage, vol.9, p.125, 1999. ,
Tract probability maps in 725 stereotaxic spaces: Analyses of white matter anatomy and tract-specific quantification, 2008. ,
, NeuroImage, vol.39, pp.336-347
, Neuroimage, vol.62, pp.782-790, 2012.
AICHA: An atlas of 730 intrinsic connectivity of homotopic areas, Journal of Neuroscience Methods, vol.254, pp.46-59, 2015. ,
SciPy: Open source scientific tools for Python, vol.733, 2001. ,
Statistical 735 Properties of Jacobian Maps and the Realization of Unbiased Large-Deformation Nonlinear 736 Image Registration, IEEE Transactions on Medical Imaging, vol.26, 2007. ,
Data Structures for Statistical Computing in Python, Proceedings of the 9th, 2010. ,
, MRI Atlas of Human White Matter, 2005.
Scikit-743 learn: Machine Learning in Python, Journal of Machine Learning Research, vol.12, 2011. ,
, , 2012.
, Data sharing in neuroimaging research, Front. Neuroinform, vol.6
Imagerie cérébrale multimodale pour l'étude des aphasies primaires progressives, vol.747, 2018. ,
, , 2018.
, Reproducible evaluation of classification methods in Alzheimer's disease: Framework and 750 application to MRI and PET data, NeuroImage
, Pypes: Workflows for Processing, p.752, 2017.
, Multimodal Neuroimaging Data. Front Neuroinform, vol.11
, , 2008.
, Construction of a 3D probabilistic atlas of human cortical structures, NeuroImage, vol.39, p.1080
, , 2016.
, PETPVC: a toolbox for performing partial volume correction techniques in positron emission 758 tomography, Physics in Medicine and Biology, vol.61, pp.7975-7993
Robust determination of the fibre orientation 761 distribution in diffusion MRI: Non-negativity constrained super-resolved spherical 762 deconvolution, NeuroImage, vol.35, pp.1459-1472, 2007. ,
Improved probabilistic streamlines 764 tractography by 2nd order integration over fibre orientation distributions, Proceedings of the 765 International Society for Magnetic Resonance in Medicine Available at: 766, 2010. ,
MRtrix: Diffusion tractography in crossing 769 fiber regions, Int. J. Imaging Syst. Technol, vol.22, pp.53-66, 2012. ,
, , 2010.
, N4ITK: Improved N3 Bias Correction, vol.29
Automated Anatomical Labeling of Activations in SPM Using a Macroscopic 775, p.774, 2002. ,
, Anatomical Parcellation of the MNI MRI Single-Subject Brain, NeuroImage, vol.15, pp.273-289
The NumPy Array: A Structure for Efficient 778 Numerical Computation, Comput. Sci. Eng, vol.13, pp.22-30, 2011. ,
, , 2007.
, Reproducibility of quantitative tractography methods applied to cerebral white matter
, NeuroImage, vol.36, pp.630-644
SurfStat: 783 A Matlab toolbox for the statistical analysis of univariate and multivariate surface and 784 volumetric data using linear mixed effects models and random field theory, NeuroImage, vol.47, p.102, 2009. ,
