Could you please phrase "home range" as a question?, J Mammal, vol.93, pp.890-902, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00740439
The home-range concept: are traditional estimators still relevant with modern telemetry technology, Philos Trans R Soc B Biol Sci, vol.365, pp.2221-2252, 2010. ,
What is a home range?, J Mammal, vol.93, pp.948-58, 2012. ,
Density estimation for statistics and data analysis. London: Chapman and Hall, 1986. ,
Kernel methods for estimating the utilization distribution in home-range studies, Ecology, vol.70, pp.164-172, 1989. ,
A rule-based ad hoc method for selecting a bandwidth in kernel home-range analyses, Anim Biotelemetry, vol.1, p.13, 2013. ,
Effects of sampling regime on the mean and variance of home range size estimates, J Anim Ecol, vol.75, pp.1393-405, 2006. ,
Spline smoothing: the equivalent variable kernel method, Ann Stat Institute of Mathematical Statistics, vol.12, pp.898-916, 1984. ,
Effects of spatiotemporal scale on autocorrelation and home range estimators, J Wildl Manag, vol.61, pp.280-90, 1997. ,
The exploratory analysis of autocorrelation in animal-movement studies, Ecol Res, vol.25, pp.673-81, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00539473
Testing for Independence of observations in animal movements, Ecology, vol.66, pp.1176-84, 1985. ,
Rigorous home-range estimation with movement data: a new autocorrelated kernel-density estimator, Ecology, vol.96, pp.1182-1190, 2015. ,
Effects of sampling effort based on GPS telemetry on home-range size estimations, J Wildl Manag, vol.66, pp.1290-300, 2002. ,
A critical review of home range studies, J Wildl Manag, vol.72, pp.290-298, 2008. ,
Effects of sample size on kernel home range estimates, J Wildl Manag, vol.63, p.739, 1999. ,
Eliminating autocorrelation reduces biological relevance of home range estimates, J Anim Ecol, vol.68, pp.221-255, 1999. ,
A new kernel density estimator for accurate homerange and species-range area estimation, Methods Ecol Evol, vol.8, pp.571-580, 2017. ,
Home range and resource selection by animals constrained by linear habitat features: an example of Blakiston's fish owl, J Appl Ecol, vol.50, pp.1350-1357, 2013. ,
Incorporating movement behavior and barriers to improve kernel home range space use estimates, J Wildl Manag, vol.74, pp.1353-60, 2010. ,
Simple boundary correction for kernel density estimation, Stat Comput, vol.3, pp.135-181, 1993. ,
Boundary kernels for distribution function estimation, Revstat Stat J, vol.11, pp.169-90, 2013. ,
Accounting for animal movement in estimation of resource selection functions: sampling and data analysis, Ecology, vol.90, pp.3554-65, 2009. ,
Weighted distributions and estimation of resource selection probability functions, Ecology, vol.87, pp.3021-3029, 2006. ,
Caught in the mesh: roads and their network-scale impediment to animal movement, Ecography, vol.40, pp.1369-80, 2017. ,
You shall not pass!": quantifying barrier permeability and proximity avoidance by animals, J Anim Ecol, vol.85, pp.43-53, 2016. ,
Analysis of radio telemetry data in studies of home range, Biometrics, vol.33, pp.85-101, 1977. ,
A general framework for the analysis of animal resource selection from telemetry data, Biometrics, vol.64, pp.968-76, 2008. ,
Correlation and studies of habitat selection: problem, red herring or opportunity?, Philos Trans R Soc B Biol Sci, vol.365, pp.2233-2277, 2010. ,
Estimating animal resource selection from telemetry data using point process models, J Anim Ecol, vol.82, pp.1155-64, 2013. ,
Statistics for spatial data, 1993. ,
Approximating point process likelihoods with GLIM, J R Stat Soc C Appl Stat, vol.41, pp.31-39, 1992. ,
Thin silicone membranes. Their permeation properties and some applications, Ann N Y Acad Sci, vol.146, pp.119-156, 1968. ,
Ctmm: an r package for analyzing animal relocation data as a continuous-time stochastic process, Methods Ecol Evol, vol.7, pp.1124-1156, 2016. ,
Reactive responses of zebras to lion encounters shape their predatorprey space game at large scale, Oikos, vol.125, pp.829-867, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-02107515
The 2013-2014 vegetation structure map of Hwange National Park, Zimbabwe, produced using free images and software, KOEDOE -African Prot Area Conserv Sci, vol.60, p.1497, 2018. ,
Dynamic approach to space and habitat use based on biased random bridges, PLoS One, vol.6, p.14592, 2011. ,
Estimating where and how animals travel: an optimal framework for path reconstruction from autocorrelated tracking data, Ecology, vol.97, pp.576-82, 2016. ,
Estimating utilization distributions from fitted step-selection functions, Ecosphere, vol.8, p.1771, 2017. ,
Home range dynamics and population regulation: an individual-based model of the common shrew Sorex araneus, Ecol Model, vol.205, pp.397-409, 2007. ,
Mechanistic home range analysis, 2004. ,
