Residual distribution schemes: current status and future trends, Comput. 877 Fluids, vol.35, issue.7, pp.641-669, 2006. ,
Residual distribution schemes: foundation and analysis, Encyclopedia of Computational Mechanics, vol.879, 2007. ,
Finite Volume Methods for Hyperbolic Problems, Cambridge Texts in 881 ,
, Applied Mathematics, 2002.
, Computational Fluid Mechanics 883 and Heat Transfer, 2012.
Riemann Solvers and Numerical Methods for Fluid Dynamics, 2009. ,
Multidimensional upwinding and grid adaptation, Numerical Methods for Wave Propagation, vol.887, p.888 ,
, , pp.33-54, 1998.
An explicit residual based approach for shallow water flows, J. Comput ,
URL : https://hal.archives-ouvertes.fr/hal-00855645
, , vol.80, pp.306-344, 2015.
Runge-Kutta residual distribution 892 schemes, J. Sci. Comput, vol.62, issue.3, pp.772-802, 2015. ,
Space-time residual distribution schemes for hyperbolic con-894 servation laws on unstructured linear finite elements, ICFD Conference on Numerical Methods for Fluid Dynamics, vol.40, pp.573-581, 2001. ,
Unconditionally stable space-time dis-898 continuous residual distribution for shallow-water flows, J. Comput. Phys, vol.253, p.899, 2013. ,
Ricchiuto, r-adaptation for shallow water flows: conservation, well-901 balancedness, efficiency, Comput. Fluids, vol.160, pp.175-203, 2016. ,
An ALE formulation of the multidimensional residual dis-903 tribution scheme for computations on moving meshes, Computational Fluid Dynamics, p.905, 2006. ,
An arbitrary Lagrangian Eulerian formula-906 tion for residual distribution schemes on moving grids, Comput. Fluids, vol.32, issue.1, p.907, 2003. ,
An efficient dynamically adaptive mesh for potentially 909 singular solutions, J. Comput. Phys, vol.172, pp.609-639, 2008. ,
Moving mesh methods for computational fluid dynamics, Contemp. Math, vol.911, pp.141-173, 2005. ,
The discrete geometric conservation law and 913 the nonlinear stability of ALE schemes for the solution of flow problems on moving 914 grids, J. Comput. Phys, vol.174, issue.2, pp.669-694, 2000. ,
Velocity-based moving mesh methods 916 for nonlinear partial differential equations, Commun. Comput. Phys, vol.10, issue.3, 2011. ,
Adaptivity with moving grids, Acta Numer, vol.18, pp.111-241, 2009. ,
An ALE formulation for explicit Runge-Kutta resid-921 ual distribution, J. Sci. Comput, vol.63, pp.502-547, 2015. ,
Upwind methods for hyperbolic conservation 923 laws with source terms, Comput. Fluids, vol.23, issue.8, pp.1049-1071, 1994. ,
Flux difference splitting and the balancing of 925 source terms and flux gradients, J. Comput. Phys, vol.165, issue.1, pp.89-125, 2000. ,
A comprehensive explanation and exercise of the 927 source terms in hyperbolic systems using Roe-type solutions. application to the 1d-2d 928 shallow water equations, Adv. Water Resour, vol.98, pp.70-96, 2016. ,
Geometric conservation laws for flow problems with moving 930 boundaries and deformable meshes, and their impact on aeroelastic computations, p.931 ,
, Comput. Method Appl. M, vol.134, issue.1-2, pp.71-90, 1996.
, of Springer Series 933 in Computational Mathematics, vol.29, 2001.
Construction of very high order residual distri-935 bution schemes for steady inviscid flow problems on hybrid unstructured meshes ,
, Comput. Phys, vol.230, issue.11, pp.4103-4136, 2011.
High order fluctuation schemes on triangular meshes, J. Sci ,
, Comput, vol.19, issue.1-3, pp.3-36, 2003.
Construction of very high order residual 940 distribution schemes for unsteady advection: preliminary results, VKI LS 2003-941 05, 33rd CFD Course, von Karman Institute for Fluid Dynamics, 2003. ,
Achieving high-order fluctuation splitting schemes by 943 extending the stencil, Comput. Fluids, vol.34, pp.443-459, 2005. ,
High order schemes for hyperbolic problems using globally continuous approx-945 imation and avoiding mass matrices, J. Sci. Comput, vol.73, pp.461-494, 2017. ,
High-order residual distribution scheme for the time-dependent 947 ,
, Euler equations of fluid dynamics, Comput. Math. Appl
High order discretisation by residual distribution schemes, p.949 ,
Unsteady high order residual 951 distribution schemes with applications to linearised Euler equations, Numerical 952 Mathematics and Advanced Applications, pp.911-919, 2009. ,
Discontinuous upwind residual distribution: A route 954 to unconditional positivity and high order accuracy, Comput. Fluids, vol.46, issue.1, 2011. ,
Contributions to the development of residual discretizations for hyper-957 bolic conservation laws with application to shallow water flows ,
A multidimensional generalization of Roe's flux 959 difference splitter for the Euler equations, Comput. Fluids, vol.22, issue.2-3, pp.215-222, 1993. ,
, High Order Discretization, p.961
, Methods, 34th Computational Fluid Dynamics Course, 2005.
Residual distribution for general time-963 dependent conservation laws, J. Comput. Phys, vol.209, issue.1, pp.249-289, 2005. ,
A difference method for numerical calculation of discontinuous solu-965 tions of the equations of hydrodynamics, Mat. Sb. (N.S.), vol.47, issue.89, pp.271-306, 1959. ,
Status of multidimensional upwind residual 967 distribution schemes and applications in aeronautics, 2000. ,
High order residual distribution 970 schemes: discontinuity capturing crosswind dissipation and extension to advection ,
Construction of second order accurate monotone and stable 983 residual distribution schemes for unsteady flow problems, J. Comput. Phys, vol.188, issue.1, pp.16-55, 2003. ,
An entropy fix for multi-dimensional upwind residual 986 distribution schemes, Comput. Fluids, vol.34, pp.617-640, 2005. ,
Upwind residual distribution for shallow-water ocean 988 modelling, Ocean Model, vol.64, pp.1-11, 2013. ,
Mathematical balancing of flux gradient and 990 source terms prior to using Roe's approximate Reimann solver, J. Comput. Phys, vol.991, pp.422-451, 2003. ,
Toward the ultimate conservative scheme: following the quest, J. Comput ,
, Phys, vol.167, issue.2, pp.277-315, 2001.
Well-balanced r-adaptive and moving mesh space-time discontinuous 995 galerkin method for the shallow water equations ,
On the C-property and generalized C-property of residual distribution 998 for the shallow water equations, J. Sci. Comput, vol.48, issue.1-3, pp.304-318, 2011. ,
Stabilized residual distribution for shallow water sim-1000 ulations, J. Comput. Phys, vol.228, issue.4, pp.1071-1115, 2009. ,
Multidimensional upwinding and grid adaptation for conservation 1002 laws, 1996. ,
Second order blended multidimensional upwind residual 1004 distribution scheme for steady and unsteady computations, J. Comput. Appl. Math. 1005, vol.215, issue.2, pp.378-389, 2008. ,
Non-oscillatory relaxation methods for the shallow-water equations in one 1007 and two space dimensions, Int. J. Numer. Meth. Fl, vol.46, issue.5, pp.457-484, 2004. ,
