Remove support for function definitions with identifier lists
Function definitions with identifier lists (often referred to as K&R functions) are deprecated for a long time. Because they are now clearly phased out everywhere and because function declarations and definitions that provide a prototypes are clearly superior we propose to remove this feature for good.
Langage de programmation [cs.PL]
