Experimental comparison of velocity estimators for a control moment gyroscope inverted pendulum - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
We consider the problem of velocity estimation for a control moment gyroscope inverted pendulum. To this end, we a consider model-free differentiator, a model-based linear observer and a model-based nonlinear differentiator. The proposed designs are implemented in hardware and the closed-loop system performance in the stabilization task is compared. Moreover, we show that the considered system cannot be partially linearized via a change of coordinates, and thus is not suitable for a recently reported class of nonlinear observers.
Automatique
cmg.pdf (1.2 Mo) Télécharger le fichier
hal-02313600 , version 1 (11-10-2019)
hal-02313600 , version 2 (07-11-2019)
  • HAL Id : hal-02313600 , version 1
Dmitry Sokolov, Stanislav Aranovskiy, Alexander A Gusev, Igor Ryadchikov. Experimental comparison of velocity estimators for a control moment gyroscope inverted pendulum. 2019. ⟨hal-02313600v1⟩
728 Consultations
707 Téléchargements
