An overview of service placement problem in Fog and Edge Computing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2019
To support the large and various applications generated by the Internet of Things(IoT), Fog Computing was introduced to complement the Cloud Computing and offer Cloud-like services at the edge of the network with low latency and real-time responses. Large-scale, geographical distribution and heterogeneity of edge computational nodes make service placement insuch infrastructure a challenging issue. Diversity of user expectations and IoT devices characteristics also complexify the deployment problem. This paper presents a survey of current research conducted on Service Placement Problem (SPP) in the Fog/Edge Computing. Based on a new clas-sification scheme, a categorization of current proposals is given and identified issues and challenges are discussed.
RR-9295.pdf (3.25 Mo) Télécharger le fichier
hal-02313711 , version 1 (11-10-2019)
hal-02313711 , version 2 (30-11-2019)
  • HAL Id : hal-02313711 , version 1
Farah Ait Salaht, Frédéric Desprez, Adrien Lebre. An overview of service placement problem in Fog and Edge Computing. [Research Report] RR-9295, Univ Lyon, EnsL, UCBL, CNRS, Inria, LIP, LYON, France. 2019, pp.43. ⟨hal-02313711v1⟩
767 Consultations
2720 Téléchargements
