Causal-Consistent Replay Debugging for Message Passing Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Debugging of concurrent systems is a tedious and error-proneactivity. A main issue is that there is no guarantee that a bug that appears in the original computation is replayed inside the debugger. This problem is usually tackled by so-called replay debugging, which allows the user to record a program execution and replay it inside the debugger. In this paper, we present a novel technique for replay debugging that we call controlled causal-consistent replay. Controlled causal-consistent replay allows the user to record a program execution and, in contrast to traditional replay debuggers, to reproduce a visible misbehavior inside the debugger including alland only its causes. In this way, the user is not distracted by the actions of others, unrelated processes.
478668_1_En_10_Chapter.pdf (385.85 Ko) Télécharger le fichier
hal-02313745 , version 1 (11-10-2019)
Paternité
Ivan Lanese, Adrián Palacios, Germán Vidal. Causal-Consistent Replay Debugging for Message Passing Programs. FORTE 2019 - 39th International Conference on Formal Techniques for Distributed Objects, Components, and Systems, Jun 2019, Copenhagen, Denmark. pp.167-184, ⟨10.1007/978-3-030-21759-4_10⟩. ⟨hal-02313745⟩
98 Consultations
40 Téléchargements
