, Plus x y) = (eval env x)`plus`(eval env y) 18 eval env (Sub x y) = (eval env x)`minus`(eval env y) 19 eval env (Mul x y) = (eval env x)`mult`(eval env y) 20 eval env (Div x y) = assert_total $ (eval env x)`div`(eval env y) 21 eval env, False 10 11 eval : (env : Env) -> (e : NumericExpression) -> Nat env
, Xc specification ver. 1.0 (x5965a, 2011.
Certificate size reduction in abstraction-carrying code, TPLP, vol.12, issue.3, pp.283-318, 2012. ,
Quasistatic voltage scaling for energy minimization with time constraints, IEEE Trans. VLSI Syst, vol.19, issue.1, pp.10-23, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00181654
Secure computer system: Unified exposition and multics interpretation, pp.1-133, 1976. ,
Idris -: Systems programming meets full dependent types, Proceedings of the 5th ACM Workshop on Programming Languages Meets Program Verification, pp.43-54, 2011. ,
A permission-dependent type system for secure information flow analysis, CSF, pp.218-232, 2018. ,
Calculating sized types, Higher-Order and Symbolic Computation, vol.14, issue.2-3, pp.261-300, 2001. ,
Refinement types for incremental computational complexity, Held as Part of the European Joint Conferences on Theory and Practice of Software, pp.406-431, 2015. ,
A comparison of commercial and military computer security policies, 1987 IEEE Symposium on Security and Privacy, pp.184-184, 1987. ,
Abstract interpretation: A unified lattice model for static analysis of programs by construction or approximation of fixpoints, Conference Record of the Fourth ACM Symposium on Principles of Programming Languages, pp.238-252, 1977. ,
Rapl: Memory power estimation and capping, Proceedings of the 16th ACM/IEEE International Symposium on Low Power Electronics and Design, pp.189-194, 2010. ,
Ensuring information security by using haskell's advanced type system, 2017 International Carnahan Conference on Security Technology (ICCST), pp.1-6, 2017. ,
A compiler framework for the reduction of worst-case execution times, Real-Time Systems, vol.46, issue.2, pp.251-300, 2010. ,
A uniform approach for the definition of security properties, FM'99 -Formal Methods, pp.794-813, 1999. ,
Energy transparency for deeply embedded programs, TACO, vol.14, issue.1, pp.1-8, 2017. ,
Security policies and security models, 1982 IEEE Symposium on Security and Privacy, pp.11-11, 1982. ,
The Java Language Specification, 2014. ,
SPEED: precise and efficient static estimation of program computational complexity, Proceedings of the 36th ACM SIGPLAN-SIGACT Symposium on Principles of Programming Languages, pp.127-139, 2009. ,
Integrated program debugging, verification, and optimization using abstract interpretation (and the ciao system preprocessor), Sci. Comput. Program, vol.58, issue.1-2, pp.115-140, 2005. ,
Multivariate amortized resource analysis, ACM Trans. Program. Lang. Syst, vol.34, issue.3, p.62, 2012. ,
Recursion and dynamic data-structures in bounded space: Towards embedded ML programming, Proceedings of the fourth ACM SIGPLAN International Conference on Functional Programming (ICFP '99), pp.70-81, 1999. ,
Programming in Haskell, 2007. ,
The montgomery powering ladder, Cryptographic Hardware and Embedded Systems -CHES 2002, pp.291-302, 2003. ,
TimeWeaver: A Tool for Hybrid Worst-Case Execution Time Analysis, 19th International Workshop on Worst-Case Execution Time Analysis, vol.72, 2019. ,
Energy modeling of software for a hardware multithreaded embedded microprocessor, ACM Trans. Embedded Comput. Syst, vol.14, issue.3, p.25, 2015. ,
Differential power analysis, Advances in Cryptology -CRYPTO' 99, pp.388-397, 1999. ,
Timing attacks on implementations of diffie-hellman, rsa, dss, and other systems, Advances in Cryptology -CRYPTO '96, pp.104-113, 1996. ,
Locks: A property specification language for security goals, Proceedings of the 33rd Annual ACM Symposium on Applied Computing, pp.1907-1915, 2018. ,
The geometry of types, The 40th Annual ACM SIGPLAN-SIGACT Symposium on Principles of Programming Languages, POPL '13, pp.167-178, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00909318
Performance analysis of embedded software using implicit path enumeration, IEEE Trans. on CAD of Integrated Circuits and Systems, vol.16, issue.12, pp.1477-1487, 1997. ,
Energy consumption analysis of programs based on XMOS isa-level models, In: LOPSTR. Lecture Notes in Computer Science, vol.8901, pp.72-90, 2013. ,
Interval-based resource usage verification by translation into horn clauses and an application to energy consumption, TPLP, vol.18, issue.2, pp.167-223, 2018. ,
On the limitations of analysing worst-case dynamic energy of processing, ACM Transactions on Embedded Computing Systems, vol.17, issue.3, 2018. ,
Proof-carrying code, Conference Record of POPL'97: The 24th ACM SIGPLAN-SIGACT Symposium on Principles of Programming Languages, pp.106-119, 1997. ,
Enabling accurate modeling of power and energy consumption in an arm-based system-on-chip. Microprocessors and Microsystems -Embedded Hardware Design, vol.37, pp.319-332, 2013. ,
BEEBS: open benchmarks for energy measurements on embedded platforms, 2013. ,
, Dude, is my code constant time? In: Design, Automation Test in Europe Conference Exhibition, pp.1697-1702, 2017.
A method for obtaining digital signatures and public-key cryptosystems, Communications of the ACM, vol.21, issue.2, pp.120-126, 1978. ,
Mathematical models of computer security, International School on Foundations of Security Analysis and Design, pp.1-62, 2000. ,
Resource usage analysis of logic programs via abstract interpretation using sized types, TPLP, vol.14, pp.739-754, 2014. ,
Energy characterization and instruction-level energy model of intel's xeon phi processor, pp.389-394, 2013. ,
Automatic generation of proof terms in dependently typed programming languages, 2018. ,
Automatically proving equivalence by type-safe reflection, Intelligent Computer Mathematics -10th International Conference, CICM 2017, pp.40-55, 2017. ,
Fable: A language for enforcing user-defined security policies, 2008 IEEE Symposium on Security and Privacy, pp.369-383, 2008. ,
Power analysis of embedded software: a first step towards software power minimization, IEEE Trans. VLSI Syst, vol.2, issue.4, pp.437-445, 1994. ,
Inferring cost equations for recursive, polymorphic and higher-order functional programs, Implementation of Functional Languages, 15th International Workshop, pp.86-101, 2003. ,
A sound type system for secure flow analysis, Journal of Computer Security, vol.4, issue.2/3, pp.167-188, 1996. ,
The worst-case execution-time prob-lem—overview of methods and survey of tools, ACM Trans. Embed. Comput. Syst, vol.7, issue.3, pp.1-36, 2008. ,
The Worst-case Execution-time Prob-lem&Mdash;Overview of Methods and Survey of Tools, ACM Trans. Embed. Comput. Syst, vol.7, issue.3, pp.1-36, 2008. ,
Energy-aware scheduling for real-time multiprocessor systems with uncertain task execution time, DAC, pp.664-669, 2007. ,
A survey on fault injection techniques, International Arab Journal of Information Technology, vol.1, issue.2, pp.171-186, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00105562
