Garbage collection for Prolog based on WAM, Communications of the ACM, vol.31, issue.6, pp.719-741, 1988. ,
Hash-consing garbage collection, 1993. ,
, Compiling with Continuations, vol.16, pp.205-214, 1992.
Infant mortality and generational garbage collection, ACM SIGPLAN Notices, vol.28, issue.4, pp.55-57, 1993. ,
Hang Pham, Controlling garbage collection and heap growth to reduce the execution time of java applications, Proceedings of the OOPSLA'01 Conference on Object Oriented Programming Systems Languages and Applications, pp.353-366, 2001. ,
Mostly-copying garbage collection picks up generations and C++, Technical note, 1989. ,
Mostly parallel garbage collection, ACM SIGPLAN Notices, vol.26, issue.6, pp.157-164, 1991. ,
ELAN: a logical framework based on computational systems, Proceedings of the 1st International Workshop on Rewriting Logic and its Applications, WRLA'96, vol.4, 1996. ,
, Proceedings of SIGPLAN'93 Conference on Programming Languages Design and Implementation, vol.28, pp.197-206, 1993.
Garbage collection in an uncooperative environment, Software-Practice and Experience, vol.18, pp.807-820, 1988. ,
Using lifetime predictors to improve memory allocation performance, 1993 ACM SIGPLAN Conference on Programming Language Design and Implementation (PLDI'93), SIGPLAN Notices, vol.28, pp.187-196, 1993. ,
Compiler support to customize the mark and sweep algorithm, ISMM'98 Proceedings of the First International Symposium on Memory Management, vol.34, pp.154-165, 1998. ,
An efficient incremental automatic garbage collector, Communications of the ACM, vol.19, issue.9, pp.522-526, 1976. ,
Combining generational and conservative garbage collection: framework and implementations, Conference Record of the Seventeenth Annual ACM Symposium on Principles of Programming Languages, pp.261-269, 1990. ,
Characterization of VAX Macsyma, 1981 ACM Symposium on Symbolic and Algebraic Computation, pp.14-19, 1981. ,
Using key object opportunism to collect old objects, OOPSLA'91 ACM Conference on Object-Oriented Systems, Language and Application, vol.26, pp.33-46, 1991. ,
, Garbage Collection for ISE Eiffel, 1999.
Garbage Collection: Algorithms for Automatic Dynamic Memory Management, 1996. ,
Warm fusion in stratego: a case study in generation of program transformation systems, Annals of Mathematics and Artificial Intelligence, 2000. ,
Promoting rewriting to a programming language: a compiler for non-deterministic rewrite programs in associative-commutative theories, Journal of Functional Programming, vol.11, issue.2, pp.207-251, 2001. ,
URL : https://hal.archives-ouvertes.fr/inria-00100926
Recursive functions of symbolic expressions and their computation by machine, Communications of the ACM, vol.3, pp.184-195, 1960. ,
A Lisp garbage collector algorithm using serial secondary storage, 1963. ,
A pattern matching compiler for multiple target languages, Proceedings of 12th Conference on Compiler Construction ,
URL : https://hal.archives-ouvertes.fr/inria-00099427
An estimate of the store size necessary for dynamic storage allocation, Journal of the ACM, vol.18, issue.3, pp.416-423, 1971. ,
Generational garbage collection for Haskell, Record of the 1993 Conference on Functional Programming and Computer Architecture, vol.523, 1993. ,
, Presentation at Sun's 2000 Worldwide Java Developer Conference (JavaOne), Inside the K Virtual Machine (KVM), 2000.
, The Java HotSpot Performance Engine Architecture, A White Paper About Sun's Second Generation Performance Technology, 2000.
Miranda--a non-strict functional language with polymorphic types, Record of the 1985 Conference on Functional Programming and Computer Architecture, vol.201, pp.1-16, 1985. ,
Generation scavenging: a non-disruptive high performance storage reclamation algorithm, Proceedings of the ACM/SIGSOFT/SIGPLAN Software Engineering Symposium on Practical Software Development Environments, vol.19, pp.157-167, 1984. ,
Efficient annotated terms, Software-Practice and Experience, vol.30, pp.259-291, 2000. ,
Compilation and memory management for ASF + SDF, Proceedings of Compiler Construction 8th International Conference, vol.1575, pp.198-213, 1999. ,
Uniprocessor garbage collection techniques, Proceedings of International Workshop on Memory Management, vol.637, pp.16-18, 1992. ,
Uniprocessor garbage collection techniques, 1994. ,
Coping with aliasing in the GNU Eiffel Compiler implementation, Software-Practice and Experience, vol.31, pp.601-613, 2001. ,
Comparative performance evaluation of garbage collection algorithms, 1989. ,
The effect of garbage collection on cache performance, 1991. ,
