, Remark 6 The above problems in (65) and (71) (or (73)), are related to the so-called force and form closure in dexterous manipulation and grasp analysis
, As Example 6 shows, the All
Dynamic simulation of rigid bodies: Modelling of frictional contacts, Impacts in Mechanical Systems. Analysis and Modelling, no. 551 in Lecture Notes in Physics, pp.61-144, 2000. ,
Numerical Methods for Nonsmooth Dynamical Systems, Lecture Notes in Applied and Computational Mechanics, vol.35, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00423530
A qualitative mathematical analysis of a class of linear variational inequalities via semi-complementarity problems, Applications in electronics. Mathematical Programming A, vol.126, issue.1, pp.31-67, 2011. ,
Preservation of prox-regularity of sets and application to constrained optimization, SIAM Journal on Optimization, vol.26, issue.1, pp.448-473, 2016. ,
Multibody systems with 3D revolute joints with clearances: an industrial case study with an experimental validation, Multibody System Dynamics, vol.42, issue.3, pp.249-282, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01562703
Formulating dynamic multi-rigid-body contact problems with friction as solvable linear complementarity problems, Nonlinear Dynamics, vol.24, pp.405-437, 1997. ,
On the existence of solutions to complementarity formulations of contact problems with friction, pp.12-21, 1997. ,
Applied Functional Analysis, 1979. ,
3-D robust stability polyhedron in multicontact, IEEE Transactions on Robotics, vol.34, issue.2, pp.388-403, 2018. ,
URL : https://hal.archives-ouvertes.fr/lirmm-01477362
Computing wrench cones for planar rigid body contact tasks, The International Journal of Robotics Research, vol.21, issue.2, pp.1053-1066, 2002. ,
Issues in computing contact forces for non-penetrating rigid bodies, Algorithmica, vol.10, issue.2-4, pp.292-352, 1993. ,
, Matrix Mathematics. Theory, Facts, and Formulas with Application to Linear Systems Theory, 2005.
, Convex Optimization Theory, 2009.
Hands for dexterous manipulation and robust grasping: a difficulty road toward simplicity, IEEE Transactions on Robotics and Automation, vol.16, issue.6, pp.652-662, 2000. ,
The contact problem in Lagrangian systems subject to bilateral and unilateral constraints, with or without sliding Coulomb's friction: a tutorial, Multibody System Dynamics, vol.38, pp.43-76, 2016. ,
Testing static equilibirum for legged robots, IEEE Transactions on Robotics, vol.24, issue.4, pp.794-807, 2008. ,
Inertial couplings between unilateral and bilateral holonomic constraints in frictionless Lagrangian systems, Multibody System Dynamics, vol.29, pp.289-325, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00825581
Kinetic quasi-velocities in unilaterally constrained Lagrangian mechanics with impacts and friction, Multibody System Dynamics, vol.32, pp.175-216, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00762986
Communications and Control Engineering, Nonsmooth Mechanics. Models, Dynamics and Control, 2016. ,
Singular mass matrix and redundant constraints in unilaterally constrained Lagrangian and Hamiltonian systems, Multibody System Dynamics, vol.35, pp.39-61, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01088286
Existence and uniqueness of solutions for non-autonomous complementarity dynamical systems, Journal of Convex Analysis, vol.17, issue.3-4, pp.961-990, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00756226
ZMP support areas for multicontact mobility under frictional constraints, IEEE Transactions on Robotics, vol.33, issue.1, pp.67-80, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-02108589
Perturbation bounds of P-matrix linear complementarity problems, SIAM Journal on Optimization, vol.18, issue.4, pp.1250-1265, 2007. ,
Quasi-positive definite operators and matrices, Linear Algebra and its Applications, vol.99, pp.161-176, 1988. ,
The Linear Complementarity Problem. Computer Science and Scientific Computing, 1992. ,
, Finite-Dimensional Variational Inequalities and Complementarity Problems, 2003.
On the unique solvability of a direct dynamics problem for mechanisms with redundant constraints and Coulomb friction, Mechanism and Machine Theory, vol.46, pp.312-334, 2011. ,
A linear complementarity formulation for contact problems with regularized friction. Mechanism and Machine Theory 105, pp.568-582, 2016. ,
Set-Valued Force Laws: Dynamics of Non-Smooth Systems, 2001. ,
Dynamical systems with unilateral contacts, Nonlinear Dynamics, 1992. ,
URL : https://hal.archives-ouvertes.fr/hal-01406288
Complementarity problems in multibody systems with planar friction, Archive of Applied Mechanics, 1993. ,
, Complementarity and Variational Inequalities in Electronics. Mathematical Analysis and its Applications, 2017.
URL : https://hal.archives-ouvertes.fr/hal-01496877
Grasp analysis as linear matrix inequality problems, IEEE Transactions on Robotics and Automation, vol.16, issue.6, pp.663-674, 2000. ,
Dynamic capturing strategy for a 2-D stick-shaped object based on friction independent collision, IEEE Transactions on Robotics, 2007. ,
Fundamentals of Convex Analysis. Grundlehren Text Editions, 2001. ,
Multibody dynamics with redundant constraints and singular mass matrix: existence, uniqueness, and determination of solutions for accelerations and constraint forces, Multibody System Dynamics, vol.30, issue.3, pp.311-341, 2013. ,
Natural coordinates for the computer analysis of multibody systems, Computer Methods in Applied Mechanics and Engineering, vol.56, issue.3, pp.309-327, 1986. ,
Existence and Uniqueness of Solutions for Accelerations for Multibody Systems with Friction. ZAMM, Z. angew. Math. Mech, vol.75, issue.1, pp.679-689, 1995. ,
Review of classical approaches for constraint enforcement in multibody systems, ASME J. of Comput. and Nonlinear Dynamics, vol.3, issue.1, p.4, 2008. ,
A set-valued force law for spatial Coulomb-Contensou friction, European Journal of Mechanics A/Solids, vol.22, issue.2, pp.193-216, 2003. ,
Stability and Convergence of Mechanical Systems with Unilateral Constraints, Lecture Notes in Applied and Computational Mechanics, vol.36, 2008. ,
Coulomb friction in two-dimensional rigid body systems, Zeitschrift für Angewandte Mathematik and Mechanik, vol.61, pp.605-615, 1981. ,
Mechanical systems of rigid bodies subject to unilateral constraints, SIAM Journal on Applied Mathematics, vol.42, issue.2, pp.281-296, 1982. ,
Planar multiple-contact problems subject to unilateral and bilateral kinetic constraints with static Coulomb friction, Nonlinear Dynamics, vol.94, pp.99-121, 2018. ,
Application of convex analysis to some problems of dry friction, Trends in Applications of Pure Mathematics to Mechanics, vol.2, pp.263-280, 1979. ,
URL : https://hal.archives-ouvertes.fr/hal-01864012
Posing multibody dynamics with friction and contact as a differential complementarity problem, ASME Journal of Computational and Nonlinear Dynamics, vol.13, p.503, 2018. ,
Dynamic balance preservation and prevention of sliding for humanoid robots in the presence of multiple spatial contacts, Multibody System Dynamics, vol.42, pp.197-218, 2018. ,
Analytic characterization of a class of three-contact frictional equilibrium postures in threedimensional gravitational environments, The International Journal of Robotics Research, vol.29, issue.1, pp.3-22, 2010. ,
Characterization of frictional multi-legged equilibrium postures on uneven terrains, The International Journal of Robotics Research, vol.36, issue.1, pp.105-128, 2017. ,
Inequality Problems in Mechanics and Applications. Convex and Nonconvex Energy Functions, 1985. ,
Robot hand grasping and related problems: optimal control and identification, The International Journal of Robotics Research, vol.13, issue.2, pp.127-136, 1994. ,
Stability characterization of rigid body contact problems with Coulomb friction, ZAMM Z. Angew. Math. Mech, vol.80, issue.10, pp.643-663, 2000. ,
Complementarity formulation and existence of solutions of dynamic rigid-body contact problems with Coulomb friction, Mathematical Programming, vol.73, issue.2, pp.199-226, 1996. ,
A complementarity approach to a quasistatic multi-rigid-body contact problem, Journal of Computational Optimization and Applications, vol.5, issue.2, pp.139-154, 1996. ,
Comparison of selected formulations for multibody systems dynamics with redundant constraints, Archive of Mechanical Engineering LXII, issue.1, pp.93-112, 2016. ,
Non-smooth engineering dynamics, Meccanica, vol.51, issue.12, pp.3167-3184, 2016. ,
Multibody Dynamics with Unilateral Contacts, 1996. ,
, Convex Analysis, 1970.
Generalized inverses of partitioned matrices, J. Soc. Indust. Appl. Math, vol.13, issue.4, pp.1033-1035, 1965. ,
Dynamics of Underactuated Multibody Systems. Solid Mechancs and Its Applications, 2014. ,
Enhance in-hand dexterous micromanipulation by exploiting adhesion forces, IEEE Transactions on Robotics, vol.34, issue.1, pp.113-125, 2018. ,
Dynamic in-hand sliding manipulation, IEEE Transactions on Robotics, vol.33, issue.4, pp.778-795, 2017. ,
Computational Flexible Multibody Dynamics. A Differential-Algebraic Approach, Differential-Algebraic Equations Forum, 2013. ,
Representation of normal cone inclusion problems in dynamics via non-linear equations, Arch. Appl. Mech, vol.76, issue.5, pp.327-348, 2006. ,
A matrix-free cone complementarity approach for solving large-scale, nonsmooth, rigid body dynamics, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.5-8, pp.439-453, 2011. ,
A complementarity-based rolling friction model for rigid contacts, Meccanica, vol.48, issue.7, pp.1643-1659, 2013. ,
Schur complements and Banachiewicz-Schur forms, Electronic Journal of Linear Algebra, vol.13, pp.405-418, 2005. ,
On the stability and instantaneous velocity of grasped frictionless objects, IEEE Transactions on Robotics and Automation, vol.8, issue.5, pp.560-572, 1992. ,
On dynamic multi-rigid-body contact problems with Coulomb friction, ZAMM-Journal of Applied Mathematics and Mechanics/Zeitschrift für Angewandte Mathematik und Mechanik, vol.77, issue.4, pp.267-279, 1997. ,
Dynamic multi-rigid-body systems with concurrent distributed contacts: Theory and examples, Philosophical Transactions: Mathematical, Physical, and Engineering Sciences, vol.359, pp.2575-2593, 1789. ,
Symmetric indefinite systems for interior point methods, Mathematical Programing, vol.58, issue.1-3, pp.1-32, 1993. ,
Lyapunov stability of a rigid body with two frictional contacts, Nonlinear Dynamics, vol.88, pp.363-393, 2017. ,
Joint reactions in rigid body mechanisms with dependent constraints. Mechaincsm and Machine Theory, vol.44, pp.2265-2278, 2009. ,
Modeling of static friction in closed-loop kineatic chains-uniqueness and parametric sensitivity, Multibody System Dynamics, vol.39, pp.337-361, 2017. ,
The Moore-Penrose inverse approach to modeling of multibody systems with redundant constraints, Advances in Mechanisms and Machine Science, Mechanisms and Machine Science, vol.73, pp.3087-3096, 2019. ,
Comparison of selected methods of handling redundant constraints in multibody systems simulations, ASME Journal of Computational and Nonlinear Dynamics, vol.8, p.7, 2013. ,
