, A 65 nm CMOS Synthesizable Digital Low-Dropout Regulator Based on Voltage-to-Time Conversion with 99.6% Current Efficiency at 10-mA Load
Tetsuya Iizuka, and Kunihiro Asada An Instruction Set Architecture for Secure, Low-Power, Dynamic IoT Communication ,
Elfadel The Connection Layout in a Lattice of Four-Terminal Switches, p.32 ,
Building High-Performance, Easy-to-Use Polymorphic Parallel Memories with HLS ,
Varbanescu Rectification of Arithmetic Circuits with Craig Interpolants in Finite Fields, p.79 ,
107 Valentino Peluso and Andrea Calimera ReRAM Based In-Memory Computation of Single Bit Error Correcting BCH Code, Yaswanth Tavva, Debjyoti Bhattacharjee, and Anupam Chattopadhyay Optimizing Performance and Energy Overheads Due to Fanout in In-Memory Computing Systems ,
167 Francesco Barchi, Gianvito Urgese, Enrico Macii, and Andrea Acquaviva Improved Test Solutions for COTS-Based Systems in Space Applications, p.187 ,
, Matteo Sonza Reorda
