, ReactiveX: An api for asynchronous programmingwith observable streams, pp.2018-2025, 2018.
Concurrent object-oriented programming, Commun. ACM, vol.33, issue.9, pp.125-141, 1990. ,
A model of concurrent computation in distributed systems, 1986. ,
Concurrent programming in ERLANG, 1993. ,
Stateful traits and their formalization, Systems & Structures, vol.34, issue.2-3, pp.83-108, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-02109190
Effective Java, 2nd Edition. The Java series ... from the source, 2008. ,
Formal Methods for Multicore Programming -15th International School on Formal Methods for the Design of Computer, Communication, and Software Systems, SFM 2015, vol.9104, pp.1-56, 2015. ,
Deny capabilities for safe, fast actors, Proceedings of the 5th International Workshop on Programming Based on Actors, Agents, and Decentralized Control, pp.1-12, 2015. ,
Adding state and visibility control to traits using lexical nesting, ECOOP 2009 -Object-Oriented Programming, 23rd European Conference, vol.5653, pp.220-243, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00498397
Ambienttalk: programming responsive mobile peer-to-peer applications with actors, Systems & Structures, vol.40, issue.3-4, pp.112-136, 2014. ,
Traits: A mechanism for fine-grained reuse, ACM Trans. Program. Lang. Syst, vol.28, issue.2, pp.331-388, 2006. ,
The revised report on the syntactic theories of sequential control and state, Theor. Comput. Sci, vol.103, issue.2, pp.235-271, 1992. ,
Design patterns: Elements of reusable object-oriented software, 1994. ,
Designing reusable classes, Journal of object-oriented programming, vol.1, issue.2, pp.22-35, 1988. ,
Concurrent object-oriented real-times systems research, SIGPLAN Notices, vol.24, issue.4, pp.203-205, 1989. ,
Inheritance in actor based concurrent object-oriented languages, Comput. J, vol.32, issue.4, pp.297-304, 1989. ,
43 years of actors: a taxonomy of actor models and their key properties, Proceedings of the 6th International Workshop on Programming Based on Actors, Agents, and Decentralized Control, pp.31-40, 2016. ,
Using prototypical objects to implement shared behavior in object oriented systems, pp.214-223 ,
Applying "design by contract", IEEE Computer, vol.25, issue.10, pp.40-51, 1992. ,
, Conference on Object-Oriented Programming Systems, Languages, and Applications (OOPSLA'86), 1986.
Revised Selected Papers, Trustworthy Global Computing, International Symposium, TGC 2005, vol.3705, pp.195-229, 2005. ,
Akka in action, 2015. ,
, Objectoriented modeling and design, vol.199, 1991.
Jcobox: Generalizing active objects to concurrent components, ECOOP 2010 -Object-Oriented Programming, 24th European Conference, vol.6183, pp.275-299, 2010. ,
Programming Elixir, Pragmatic Bookshelf, 2018. ,
Object-oriented concurrent programming in ABCL/1, pp.258-268 ,
URL : https://hal.archives-ouvertes.fr/hal-01221585
