Evaluating smartphone performance for cellular power measurement - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2019
From crowdsource data collection to automation and ro-botics, mobile smartphones are well suited for various use cases given the rich hardware components they feature. Researchers can now have access to various sensors such as barometers, magnetometers, orientation sensors, in addition to multiple wireless technologies all on a single and relatively cheap mobile smartphone. In this work, we study the performance of smartphones to measure cellular wireless power. We performed our experiments inside an anechoic chamber in order to compare the measurements of smartphone to the ones obtained with professional spectrum analyzer. We first evaluate the effect of orientation on the received power, then we propose a way to improve the accuracy of smartphone power measurements by using the orientation sensors. We improve the accuracy of the measurements from 25 dBm RMSE to no more than 6 dBm RMSE. We also show how we can exploit the characteristics of the reception pattern of the smartphone to determine the angle of arrival of the signal.
smartphones_wireless_power.pdf (2.14 Mo) Télécharger le fichier
Calibration_random_H_pol.pdf (22.09 Ko) Télécharger le fichier
Calibration_random_H_pol2.pdf (22.07 Ko) Télécharger le fichier
Calibration_random_H_pol2_backup.pdf (25.5 Ko) Télécharger le fichier
Calibration_random_H_pol_backup.pdf (25.63 Ko) Télécharger le fichier
RMSE_unaligned_source.pdf (10.77 Ko) Télécharger le fichier
RMSE_unaligned_source_backup.pdf (12.76 Ko) Télécharger le fichier
UE (1).png (1.36 Mo) Télécharger le fichier
UE_antenna.pdf (172.51 Ko) Télécharger le fichier
UEs_tested.pdf (134.91 Ko) Télécharger le fichier
UEs_tested2.pdf (273.21 Ko) Télécharger le fichier
angle_errors.pdf (16.88 Ko) Télécharger le fichier
angle_errors_backup.pdf (25.27 Ko) Télécharger le fichier
antenna_loc.odg (10.59 Ko) Télécharger le fichier
api_compare.pdf (16.89 Ko) Télécharger le fichier
api_compare_backup.pdf (20.29 Ko) Télécharger le fichier
api_compare_backup_backup.pdf (20.87 Ko) Télécharger le fichier
calib_idx_rmse_annot (1).png (807.79 Ko) Télécharger le fichier
calib_idx_rmse_annot.pdf (192.06 Ko) Télécharger le fichier
calib_idx_rmse_annot2.pdf (61.52 Ko) Télécharger le fichier
calib_idx_rmse_annot2_backup.pdf (68.85 Ko) Télécharger le fichier
calibration_20_40 (1).png (339.08 Ko) Télécharger le fichier
chamber.pdf (24.96 Ko) Télécharger le fichier
chamber_backup.pdf (22.56 Ko) Télécharger le fichier
correlation_plots.pdf (11.49 Ko) Télécharger le fichier
device_rotation.pdf (37.5 Ko) Télécharger le fichier
device_rotation3.pdf (35.87 Ko) Télécharger le fichier
experiments.pdf (31.08 Ko) Télécharger le fichier
heatmap_all_devices.pdf (45.93 Ko) Télécharger le fichier
heatmap_all_devices_backup.pdf (86.21 Ko) Télécharger le fichier
heatmap_h.pdf (16.48 Ko) Télécharger le fichier
heatmap_h_backup.pdf (23.37 Ko) Télécharger le fichier
heatmap_v.pdf (16.15 Ko) Télécharger le fichier
heatmap_v_backup.pdf (23.02 Ko) Télécharger le fichier
hm_differnent_tx.pdf (25.31 Ko) Télécharger le fichier
hm_differnent_tx_backup.pdf (25.31 Ko) Télécharger le fichier
locating_source.pdf (16.33 Ko) Télécharger le fichier
mainlobe_received_power_heatmaps.pdf (36.76 Ko) Télécharger le fichier
mainlobe_received_power_heatmaps2.pdf (37.28 Ko) Télécharger le fichier
mainlobe_received_power_heatmaps2_backup.pdf (64.04 Ko) Télécharger le fichier
mainlobe_received_power_heatmaps_backup.pdf (61.54 Ko) Télécharger le fichier
matrices.pdf (17.44 Ko) Télécharger le fichier
mean_power_axis_rotation.pdf (13.39 Ko) Télécharger le fichier
mean_power_axis_rotation_backup.pdf (12.23 Ko) Télécharger le fichier
orient_error.pdf (7.49 Ko) Télécharger le fichier
orient_error_backup.pdf (9.65 Ko) Télécharger le fichier
out.pdf (20.28 Ko) Télécharger le fichier
outdoor_exp.pdf (599.82 Ko) Télécharger le fichier
outdoor_exp_backup.pdf (1.48 Mo) Télécharger le fichier
process.pdf (37.18 Ko) Télécharger le fichier
rmses.pdf (22.23 Ko) Télécharger le fichier
rmses_backup.pdf (12.82 Ko) Télécharger le fichier
sector_antenna (1).jpg (526.48 Ko) Télécharger le fichier
source_axis_rotation_heatmaps2.pdf (37 Ko) Télécharger le fichier
source_axis_rotation_heatmaps2_backup.pdf (36.54 Ko) Télécharger le fichier
source_axis_rotation_heatmaps2_backup_backup.pdf (62.83 Ko) Télécharger le fichier
unknown_ue_mcm.pdf (10.81 Ko) Télécharger le fichier
unknown_ue_mcm_backup.pdf (12 Ko) Télécharger le fichier
var_outdoor.pdf (8.07 Ko) Télécharger le fichier
var_outdoor_backup.pdf (9.88 Ko) Télécharger le fichier
hal-02320342 , version 1 (21-10-2019)
hal-02320342 , version 2 (06-04-2020)
hal-02320342 , version 3 (14-04-2020)
  • HAL Id : hal-02320342 , version 1
Yanis Boussad, Leonardo Lizzi, Fabien Ferrero, Arnaud Legout. Evaluating smartphone performance for cellular power measurement. [Research Report] UCA, Inria; UCA, LEAT. 2019. ⟨hal-02320342v1⟩
460 Consultations
638 Téléchargements
