Evaluating Smartphone Accuracy for LTE Power Measurement - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2019
Smartphones are today relatively cheap devices that embed a large variety of sensors such as magnetometers or orientation sensors, but also the hardware to connect to most wireless communication technologies such as Wi-Fi, Bluetooth, or cellular networks. For this reason, companies, such as OpenSignal or Tutela use smartphones to make crowd-based measurements of the received power from the cellular infrastructure to help operators manage their infrastructure. However, to the best of our knowledge, the accuracy of such measurements has never been rigorously assessed. The goal of this paper is to assess how accurate are measurements of received power from a 4G (LTE) antenna when performed from a Commercial Off-The-Shelf~(COTS) smartphone in different environments. We first evaluate the granularity and limitations of the Android API that returns the received power. We explore how reliable are the measurements from a mono-polarized antenna in a fully controlled environment. We show that the orientation of the smartphone, the position of the source, and the distance to the source has a significant impact on the accuracy of the measurements. We introduce several calibration techniques based on radiation matrices manipulations and machine learning to calibrate the measurements, that is, to improve the accuracy to less than 5 dBm RMSE compared to a professional equipment. Finally, we explore how reliable are measurements in an outdoor environment, in the context of a multi-polarized antenna.
main.pdf (2.37 Mo) Télécharger le fichier
Calibration_random_H_pol.pdf (22.09 Ko) Télécharger le fichier
Calibration_random_H_pol2.pdf (23.13 Ko) Télécharger le fichier
Evaluating Smartphone Accuracy for LTE Power Measurement.pdf (2.28 Mo) Télécharger le fichier
SIGCOM_log_processing.pdf (41.03 Ko) Télécharger le fichier
SIGMETRICS_setup.pdf (72.7 Ko) Télécharger le fichier
angle_errors.pdf (16.88 Ko) Télécharger le fichier
api_compare.pdf (16.89 Ko) Télécharger le fichier
api_compare_backup.pdf (20.29 Ko) Télécharger le fichier
api_compare_backup_backup.pdf (20.87 Ko) Télécharger le fichier
chamber.pdf (24.96 Ko) Télécharger le fichier
correlation_plots.pdf (13.49 Ko) Télécharger le fichier
device_rotation.pdf (37.5 Ko) Télécharger le fichier
device_rotation3.pdf (35.87 Ko) Télécharger le fichier
experiments.pdf (31.08 Ko) Télécharger le fichier
framework.pdf (19.93 Ko) Télécharger le fichier
heatmap_all_devices.pdf (45.93 Ko) Télécharger le fichier
heatmap_all_devices_backup.pdf (86.21 Ko) Télécharger le fichier
heatmap_h.pdf (21.42 Ko) Télécharger le fichier
heatmap_h_backup.pdf (23.37 Ko) Télécharger le fichier
heatmap_v.pdf (21.08 Ko) Télécharger le fichier
hm_differnent_tx.pdf (25.6 Ko) Télécharger le fichier
locating_source.pdf (15.36 Ko) Télécharger le fichier
log_processing.pdf (119.76 Ko) Télécharger le fichier
mainlobe_received_power_heatmaps.pdf (36.76 Ko) Télécharger le fichier
mainlobe_received_power_heatmaps2.pdf (38.15 Ko) Télécharger le fichier
mainlobe_received_power_heatmaps2_backup.pdf (64.04 Ko) Télécharger le fichier
mainlobe_received_power_heatmaps_backup.pdf (61.54 Ko) Télécharger le fichier
mean_power_axis_rotation.pdf (13.72 Ko) Télécharger le fichier
ml_calib_selection.pdf (13.94 Ko) Télécharger le fichier
out.pdf (20.28 Ko) Télécharger le fichier
outdoor_exp.pdf (230.73 Ko) Télécharger le fichier
process.pdf (37.18 Ko) Télécharger le fichier
rmses.pdf (17.4 Ko) Télécharger le fichier
rmses_source.pdf (25.4 Ko) Télécharger le fichier
rmses_tx.pdf (22.88 Ko) Télécharger le fichier
setup.pdf (119.94 Ko) Télécharger le fichier
source_axis_rotation_heatmaps2.pdf (36.95 Ko) Télécharger le fichier
variation.pdf (700.45 Ko) Télécharger le fichier
hal-02320342 , version 1 (21-10-2019)
hal-02320342 , version 2 (06-04-2020)
hal-02320342 , version 3 (14-04-2020)
  • HAL Id : hal-02320342 , version 2
Yanis Boussad, Mohamed Naoufal Mahfoudi, Arnaud Legout, Leonardo Lizzi, Fabien Ferrero, et al.. Evaluating Smartphone Accuracy for LTE Power Measurement. [Research Report] UCA, Inria; UCA, LEAT. 2019. ⟨hal-02320342v2⟩
460 Consultations
638 Téléchargements
