Matched-pairs tests of homogeneity with applications to homologous nucleotide sequences, Bioinformatics, vol.22, pp.1225-1231, 2006. ,
MOLPHY version 2.3: programs for molecular phylogenetics based on maximum likelihood, Comput. Sci. Monogr, vol.28, pp.1-150, 1996. ,
A new look at the statistical model identification, IEEE Trans. Autom. Contr. ACM, vol.19, pp.716-723, 1974. ,
A Bayesian compound stochastic process for modeling nonstationary and nonhomogeneous sequence evolution, Mol. Biol. Evol, vol.23, pp.2058-2071, 2006. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00135037
A site-and time-heterogeneous model of amino acid replacement, Mol. Biol. Evol, vol.25, pp.842-858, 2008. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00324422
Bayesian model adequacy and choice in phylogenetics, Mol. Biol. Evol, vol.19, pp.1171-1180, 2002. ,
Parallel adaptation to high temperature in the archaean eon, Nature, vol.456, pp.942-945, 2008. ,
Efficient likelihood computations with nonreversible models of evolution, Syst. Biol, vol.55, pp.756-768, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00427908
What genomes have to say about the evolution of the Earth, Gondwana Res, vol.21, pp.483-494, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00698400
A test for symmetry in contingency tables, J. Am. Stat. Assoc, vol.43, pp.572-574, 1948. ,
Phylogeny and evolution of the Archaea: one hundred genomes later, Curr. Opion. Microbiol, vol.14, pp.274-281, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00598326
Selection of conserved blocks from multiple alignments for their use in phylogenetic analysis, Mol. Biol. Evol, vol.17, pp.540-552, 2000. ,
The archaebacterial origin of eukaryotes, Proc. Natl Acad. Sci. U. S. A, vol.105, pp.20356-20361, 2008. ,
Tunicates and not cephalochordates are the closest living relatives of vertebrates, Nature, vol.439, pp.965-968, 2006. ,
URL : https://hal.archives-ouvertes.fr/halsde-00315436
The timing of eukaryotic evolution: does a relaxed molecular clock reconcile proteins and fossils?, Proc. Natl Acad. Sci. U. S. A, vol.101, pp.15386-15391, 2004. ,
URL : https://hal.archives-ouvertes.fr/halsde-00193035
Non-homogeneous models of sequence evolution in the Bio++ suite of libraries and programs, BMC Evol. Biol, vol.8, p.255, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00428202
Bio++: a set of C++ libraries for sequence analysis, phylogenetics, molecular evolution and population genetics, BMC Bioinform, vol.7, p.188, 2006. ,
URL : https://hal.archives-ouvertes.fr/halsde-00323971
Efficient selection of branch-specific models of sequence evolution, Mol. Biol. Evol, vol.29, pp.1861-1874, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00965698
MUSCLE: multiple sequence alignment with high accuracy and high throughput, Nucleic Acids Res, vol.32, pp.1792-1797, 2004. ,
Evolutionary trees from DNA sequences: a maximum likelihood approach, J. Mol. Evol, vol.17, pp.368-376, 1981. ,
Inferring phylogenies, 2004. ,
Evolution of increased complexity in a molecular machine, Nature, vol.481, pp.360-364, 2012. ,
, Modeling compositional heterogeneity. Syst. Biol, vol.53, pp.485-495, 2004.
Inferring phylogenies from DNA sequences of unequal base compositions, Proc. Natl Acad. Sci. U. S. A, vol.92, pp.11317-11321, 1995. ,
URL : https://hal.archives-ouvertes.fr/hal-02320510
Inferring pattern and process: maximumlikelihood implementation of a nonhomogeneous model of DNA sequence evolution for phylogenetic analysis, Mol. Biol. Evol, vol.15, pp.871-879, 1998. ,
URL : https://hal.archives-ouvertes.fr/hal-00428472
Relationships between genomic G+C content, RNA secondary structures, and optimal growth temperature in prokaryotes, J. Mol. Evol, vol.44, pp.632-636, 1997. ,
URL : https://hal.archives-ouvertes.fr/hal-00434982
A nonhyperthermophilic common ancestor to extant life forms, Science, vol.283, pp.220-221, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-00428447
Palaeotemperature trend for Precambrian life inferred from resurrected proteins, Nature, vol.451, pp.704-708, 2008. ,
A reversible jump method for Bayesian phylogenetic inference with a nonhomogeneous substitution model, Mol. Biol. Evol, vol.24, pp.1286-1299, 2007. ,
Theory and applications of correspondence analysis, 1984. ,
Adaptation to environmental temperature is a major determinant of molecular evolutionary rates in Archaea, Mol. Biol. Evol, vol.28, pp.2661-2674, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00697929
A simple, fast, and accurate algorithm to estimate large phylogenies by maximum likelihood, Syst. Biol, vol.52, pp.696-704, 2003. ,
Analyzing protein structure and function using ancestral gene reconstruction, Curr. Opin. Struct. Biol, vol.20, pp.360-366, 2010. ,
Ribosomal RNA trees misleading, Nature, vol.361, p.23, 1993. ,
Nonhomogeneous model of sequence evolution indicates independent origins of primary endosymbionts within the Enterobacteriales (Gamma-Proteobacteria), Mol. Biol. Evol, vol.22, pp.520-532, 2005. ,
Tracing the decay of the historical signal in biological sequence data, Syst. Biol, vol.53, pp.623-637, 2004. ,
On the origin and evolution of thermophily: reconstruction of functional precambrian enzymes from ancestors of Bacillus, Mol. Biol. Evol, vol.29, pp.825-835, 2011. ,
A simple sequentially rejective multiple test procedure. Scand, J. Stat, vol.6, pp.65-70, 1979. ,
Enzyme functional evolution through improved catalysis of ancestrally nonpreferred substrates, Proc. Natl Acad. Sci. U. S. A, vol.109, pp.2966-2971, 2012. ,
Bayesian inference of phylogeny and its impact on evolutionary biology, Science, vol.294, pp.2310-2314, 2001. ,
Reducing model complexity of the general Markov model of evolution, Mol. Biol. Evol, vol.28, pp.3045-3059, 2011. ,
Two stationary nonhomogeneous Markov models of nucleotide sequence evolution, Syst. Biol, vol.60, pp.74-86, 2011. ,
Estimation of phylogeny using a general Markov model, Evol. Bioinform. Online, vol.1, pp.62-80, 2005. ,
Estimation of phylogeny and invariant sites under the general Markov model of nucleotide sequence evolution, Syst. Biol, vol.56, pp.155-162, 2007. ,
The biasing effect of compositional heterogeneity on phylogenetic estimates may be underestimated, Syst. Biol, vol.53, pp.638-643, 2004. ,
Bioinformatics-Volume I: data, sequences analysis and evolution, pp.331-363, 2008. ,
The rapid generation of mutation data matrices from protein sequences, Comput. Appl. Biosci, vol.8, pp.275-282, 1992. ,
Reconstructing evolutionary trees from DNA and protein sequences: paralinear distances, Proc. Natl Acad. Sci. U. S. A, vol.91, pp.1455-1459, 1994. ,
A Bayesian mixture model for across-site heterogeneities in the amino acid replacement process, Mol. Biol. Evol, vol.21, pp.1095-2004, 2004. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00108585
An improved general amino acid replacement matrix, Mol. Biol. Evol, vol.25, pp.1307-1320, 2008. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00324106
Empirical profile mixture models for phylogenetic reconstruction, Bioinformatics, vol.24, pp.2317-2323, 2008. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00324090
Phylogenetic mixture models for proteins, Phil. Trans. R. Soc. Lond. B, vol.363, pp.3965-3976, 2008. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00365645
Recovering evolutionary trees under a more realistic model of sequence evolution, Mol. Biol. Evol, vol.11, pp.605-612, 1994. ,
Phylogeny-aware gap placement prevents errors in sequence alignment and evolutionary analysis, Science, vol.320, pp.1632-1635, 2008. ,
Ultra-fast sequence clustering from similarity networks with SiLiX, BMC Bioinform, vol.12, p.116, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00698365
Dynamic evolution of base composition: causes and consequences in avian phylogenomics, Mol. Biol. Evol, vol.28, pp.2197-2210, 2011. ,
An alignment confidence score capturing robustness to guide-tree uncertainty, Mol. Biol. Evol, vol.27, pp.1759-1767, 2010. ,
Resolving difficult phylogenetic questions: why more sequences are not enough, PLoS Biol, vol.9, p.1000602, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00594558
jModelTest: phylogenetic model averaging, Mol. Biol. Evol, vol.25, pp.1253-1256, 2008. ,
MODELTEST: testing the model of DNA substitution, Bioinformatics, vol.14, pp.817-818, 1998. ,
Does choice in model selection affect maximum likelihood analysis?, Syst. Biol, vol.57, pp.76-85, 2008. ,
Genome-scale approaches to resolving incongruence in molecular phylogenies, Nature, vol.425, pp.798-804, 2003. ,
Estimating the dimension of a model, Ann. Statist, vol.6, pp.461-464, 1978. ,
Should phylogenetic models be trying to "fit an elephant"?, Trends Genet, vol.21, pp.307-309, 2005. ,
Is the general time-reversible model bad for molecular phylogenetics?, Syst. Biol, vol.61, pp.1069-1074, 2012. ,
Lie Markov models, J. Theor. Biol, vol.298, pp.16-31, 2012. ,
Evolutionary distance estimation under heterogeneous substitution pattern among lineages, Mol. Biol. Evol, vol.19, pp.1727-1736, 2002. ,
ADE-4: a multivariate analysis and graphical display software, Statist. Comput, vol.7, pp.75-83, 1997. ,
URL : https://hal.archives-ouvertes.fr/hal-00434994
Relaxed molecular clocks, the bias-variance trade-off, and the quality of phylogenetic inference, Syst. Biol, vol.59, pp.1-8, 2010. ,
A general empirical model of protein evolution derived from multiple protein families using a maximumlikelihood approach, Mol. Biol. Evol, vol.18, pp.691-699, 2001. ,
Maximum likelihood phylogenetic estimation from DNA sequences with variable rates over sites: approximate methods, J. Mol. Evol, vol.39, pp.306-314, 1994. ,
Likelihood ratio tests for detecting positive selection and application to Primate Lysozyme evolution, Mol. Biol. Evol, vol.15, pp.568-573, 1998. ,
Computational molecular evolution, 2006. ,
PAML 4: phylogenetic analysis by maximum likelihood, Mol. Biol. Evol, vol.24, pp.1586-1591, 2007. ,
A new method of inference of ancestral nucleotide and amino acid sequences, Genetics, vol.141, pp.1641-1650, 1995. ,
On the use of nucleic acid sequences to infer early branchings in the Tree of Life, Mol. Biol. Evol, vol.12, pp.451-458, 1995. ,
Protein and DNA sequence determinants of thermophilic adaptation, PLoS Comput. Biol, vol.3, p.5, 2007. ,
Fitting nonstationary general-time-reversible models to obtain edge-lengths and frequencies for the Barry-Hartigan model, Syst. Biol, vol.61, pp.927-940, 2012. ,
