Symmetric coupling for eddy current problems, SIAM J. Numer. Anal, vol.40, pp.41-65, 2002. ,
On traces for functional spaces related to Maxwell's equations.Part I: An integration by parts formula in Lipschitz polyhedra, Instituto di Analisi Numerica, 1999. ,
On traces for functional spaces related to Maxwell's equations.Part II: Hodge decompositions on the boundary of Lipschitz polyhedra and applicatons, Instituto di Analisi Numerica, 1999. ,
A mixed Finite Element Method for second order elliptic problems, vol.606, pp.292-315, 1977. ,
Impedance transmission conditions for eddy current problems, 2017. ,
Boundary Element Method for 3D Eddy Current Problems With a Conductive Thin Layer, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01645414
3-D Integral Formulation Using Facet Elements for Thin Conductive Shells Coupled With an External Circuit, IEEE Transactions on Magnetics, vol.51, p.3, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00998745
Coupled boundary-element scheme for eddy-current computation, Journal of Engineering Mathematics, vol.51, pp.231-250, 2005. ,
, Eddy Current Approximation of Maxwell Equations: Theory, Algorithms and Applications, vol.4, 2010.
Series solution of an eddy-current problem for a sphere with varying conductivity and permeability profiles, IEEE Transactions on Magnetics, vol.35, issue.6, pp.4445-4451, 1999. ,
A boundary integral formulation of the eddy-current problem, IEEE Transactions on Magnetics, vol.16, issue.5, pp.1086-1088, 1980. ,
A boundary integral method for eddy current flow around cracks in thin plates, IEEE Trans. on Magnetics, issue.2, p.467, 1982. ,
Robust transmission conditions of high order for thing conducting sheets in two dimensions, IEEE Trans. Magn, vol.50, issue.2, pp.41-44, 2014. ,
A unified analysis of transmission conditions for thin conducting sheets in the time-harmonic eddy current model, SIAM J. Appl. Math, vol.73, issue.6, pp.1980-2003, 2013. ,
A New Integral Formulation for Eddy Current Computation in Thin Conductive Shells, IEEE Transactions on Magnetics, vol.48, issue.2, pp.427-430, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00727820
Asymptotic expansion of steady-state potential in a high contrast medium with a thin resistive layer, Applied Mathematics and Computation, vol.221, pp.48-65, 2013. ,
URL : https://hal.archives-ouvertes.fr/inria-00442659
