Impact of scaling on neutron-induced soft error in srams from a 250 nm to a 22 nm design rule, IEEE Transactions on Electron Devices, vol.57, issue.7, pp.1527-1538, 2010. ,
Concurrent error detection in sequential circuits implemented using fpgas with embedded memory blocks, Proceedings. 10th IEEE International On-Line Testing Symposium, pp.67-72, 2004. ,
Soft error mitigation for sram-based fpgas, 23rd IEEE VLSI Test Symposium (VTS'05, pp.207-212, 2005. ,
2012) 1528 -1530 Special Section Thermal, mechanical and multi-physics simulation and experiments in micro-electronics and micro-systems, Microelectronics Reliability, vol.52, issue.7, 2011. ,
Error correction for multi-level nand flash memory using reed-solomon codes, IEEE Workshop on Signal Processing Systems, pp.94-99, 2008. ,
Soft-error-resilient fpgas using built-in 2-d hamming product code, IEEE Transactions on Very Large Scale Integration (VLSI) Systems, vol.20, issue.2, pp.248-256, 2012. ,
A multiple bit upset tolerant sram memory, ACM Trans. Des. Autom. Electron. Syst, vol.8, issue.4, pp.577-590, 2003. ,
Low complexity cross parity codes for multiple and random bit error correction, Thirteenth International Symposium on Quality Electronic Design (ISQED), pp.57-62, 2012. ,
Writing cosets of a convolutional code to increase the lifetime of flash memory, 2012 50th Annual Allerton Conference on Communication, Control, and Computing (Allerton), pp.308-318, 2012. ,
Efficient in-memory computing architecture based on crossbar arrays, 2015 IEEE International Electron Devices Meeting (IEDM), 2015. ,
Reram technology evolution for storage class memory application, pp.432-435, 2016. ,
Emerging memory technologies: Recent trends and prospects, IEEE Solid-State Circuits Magazine, vol.8, issue.2, pp.43-56, 2016. ,
An overview of materials issues in resistive random access memory, Journal of Materiomics, vol.1, issue.4, pp.285-295, 2015. ,
A complementary resistive switchbased crossbar array adder, IEEE Journal on Emerging and Selected Topics in Circuits and Systems, vol.5, issue.1, pp.64-74, 2015. ,
Brains are made of memristors, IEEE Circuits and Systems Magazine, vol.14, issue.1, pp.12-36, 2014. ,
The programmable logic-in-memory (PLiM) computer, p.2016 ,
Automation Test in Europe Conference Exhibition (DATE), pp.427-432, 2016. ,
Pipelayer: A pipelined reram-based accelerator for deep learning, 2017 IEEE International Symposium on High Performance Computer Architecture (HPCA), pp.541-552, 2017. ,
Replacing linear hamming codes by robust nonlinear codes results in a reliability improvement of memories, 2009 IEEE/IFIP International Conference on Dependable Systems Networks, pp.514-523, 2009. ,
SHA-3 implementation using ReRAM based in-memory computing architecture, 2017 18th International Symposium on Quality Electronic Design (ISQED), pp.325-330, 2017. ,
In-memory data compression using ReRAMs, Emerging Technology and Architecture for Big-data Analytics, pp.275-291, 2017. ,
Vhdl design and fpga implementation of a fully parallel bch siso decoder, 2010 5th International Symposium On I/V Communications and Mobile Network, pp.1-4, 2010. ,
Hardware implementation of shortened (48,38) reed solomon forward error correcting code, 7th International Multi Topic Conference, vol.INMIC, pp.90-95, 2003. ,
High-throughput finite field multipliers using redundant basis for fpga and asic implementations, IEEE Transactions on Circuits and Systems I: Regular Papers, vol.62, issue.1, pp.110-119, 2015. ,
, 2019 IFIP/IEEE International Conference on Very Large Scale Integration, pp.1-6, 2019.
, Computational aspects of modular forms and Galois representations, 2011.
URL : https://hal.archives-ouvertes.fr/hal-00630395
, Recurrent methods for constructing irreducible polynomials over fq of odd characteristics. Finite Fields and Their Applications, vol.9, pp.39-58, 2003.
Decoding binary bch codes, Proceedings IEEE Southeastcon '95. Visualize the Future, pp.67-73, 1995. ,
ReVAMP: ReRAM based VLIW architecture for in-memory computing, Design, Automation Test in Europe Conference Exhibition (DATE, pp.782-787, 2017. ,
Simulation of taox-based complementary resistive switches by a physics-based memristive model, 2014 IEEE International Symposium on Circuits and Systems (ISCAS), pp.1420-1423, 2014. ,
Beyond von neumannlogic operations in passive crossbar arrays alongside memory operations, Nanotechnology, vol.23, issue.30, p.305205, 2012. ,
Enabling in-memory computation of binary BLAS using ReRAM crossbar arrays, 2016 IFIP/IEEE International Conference on Very Large Scale Integration (VLSI-SoC). (Sep. 2016) 1-6 32. : Emerging research devices (ERD) report. In: International Technology Roadmap for Semiconductors (ITRS), 2013. ,
