An Instruction Set Architecture for Secure, Low-Power, Dynamic IoT Communication - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This chapter presents an instruction set architecture (ISA) dedicated to the rapid and efficient implementation of single-channel IoT communication interfaces. The architecture is meant to provide a programming interface for the implementation of signaling protocols based on the recently introduced pulsed-index schemes. In addition to the traditional aspects of ISA design such as addressing modes, instruction types, instruction formats, registers, interrupts, and external I/O, the ISA includes special-purpose instructions that facilitate bit stream encoding and decoding based on the pulsed-index techniques. Verilog HDL is used to synthesize a fully functional processor based on this ISA and provide both an FPGA implementation and a synthesised ASIC design in GLOBALFOUNDRIES 65 nm. The ASIC design confirms the low-power features of this ISA with consumed power around 31 $µ$ W and energy efficiency of less than 10 pJ/bit. Finally, this chapter shows how the basic ISA can be extended to include cryptographic features in support of secure IoT communication.
485996_1_En_2_Chapter.pdf (435.17 Ko) Télécharger le fichier
hal-02321776 , version 1 (21-10-2019)
Paternité
Shahzad Muzaffar, Ibrahim Elfadel. An Instruction Set Architecture for Secure, Low-Power, Dynamic IoT Communication. 26th IFIP/IEEE International Conference on Very Large Scale Integration - System on a Chip (VLSI-SoC), Oct 2018, Verona, Italy. pp.14-31, ⟨10.1007/978-3-030-23425-6_2⟩. ⟨hal-02321776⟩
115 Consultations
47 Téléchargements
