Synthesis of Branched-Chain Sugars with a DHAP-Dependent Aldolase: Ketones are Electrophile Substrates of Rhamnulose-1- phosphate Aldolases - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Angewandte Chemie International Edition Année : 2018
Ekaterina Darii
Jean-Louis Petit
Aline Mariage
Marcel Salanoubat
Véronique de Berardinis
Dihydroxyacetone phosphate (DHAP)-dependent rhamnulose aldolases display an unprecedented versatility for ketones as electrophile substrates. We selected and characterized a rhamnulose aldolase from Bacteroides thetaiotaomicron (RhuABthet) to provide a proof of concept. DHAP was added as a nucleophile to several a-hydroxylated ketones used as electrophiles. This aldol addition was stereoselective and produced branched-chain monosaccharide adducts with a ter-tiary alcohol moiety. Several aldols were readily obtained in good to excellent yields (from 76 to 95 %). These results contradict the general view that aldehydes are the only electrophile substrates for DHAP-dependent aldolases and provide a new CÀC bond-forming enzyme for stereoselective synthesis of tertiary alcohols.
RhuAketones-laurent-2018.pdf (644.91 Ko) Télécharger le fichier
hal-02323732 , version 1 (22-10-2019)
Victor Laurent, Ekaterina Darii, Angelina Aujon, Marine Debacker, Jean-Louis Petit, et al.. Synthesis of Branched-Chain Sugars with a DHAP-Dependent Aldolase: Ketones are Electrophile Substrates of Rhamnulose-1- phosphate Aldolases. Angewandte Chemie International Edition, 2018, 57 (19), pp.5467 - 5471. ⟨10.1002/anie.201712851⟩. ⟨hal-02323732⟩
263 Consultations
221 Téléchargements
