Physical Properties of Carbon Nanotubes, 1998. ,
, Nat. Nanotechnol, vol.2, pp.605-620, 2007.
Carbon nanotubes based transistors as gas sensors: State of the art and critical review, Sensors Actuators, B Chem, vol.140, pp.304-318, 2009. ,
Current understanding of the growth of carbon nanotubes in catalytic chemical vapour deposition, Carbon N. Y, vol.58, pp.2-39, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01067024
Controlling the diameter of carbon nanotubes in chemical vapor deposition method by carbon feeding, J. Phys. Chem. B, vol.110, pp.20254-20261, 2006. ,
Selective synthesis of large diameter, highly conductive and high density single-walled carbon nanotubes by a thiopheneassisted chemical vapor deposition method on transparent substrates, Nanoscale, vol.8, pp.14156-14162, 2016. ,
Chiralselective growth of single-walled carbon nanotubes on lattice-mismatched epitaxial cobalt nanoparticles, Sei. Rep, vol.3, p.1460, 2013. ,
Predominant (6,5) single-walled carbon nanotube growth on a copper-promoted iron catalyst, J. Am. Chem. Soc, vol.132, pp.13994-14000, 2010. ,
Narrow (n,m)-distribution of single-walled carbon nanotubes grown using a solid supported catalyst, J. Am. Chem. Soc, vol.125, pp.11186-11193, 2003. ,
Growth of semiconducting single-walled carbon nanotubes by using ceria as catalyst supports, Nano Lett, vol.14, pp.512-519, 2014. ,
Preferential growth of single-walled carbon nanotubes with metallic conductivity, Science, vol.326, pp.116-120, 2009. ,
On the origin of preferential growth of semiconducting single-walled carbon nanotubes, J. Phys. Chem. B, vol.109, pp.6968-71, 2005. ,
Diameter and chiral angle distribution dependencies on the carbon precursors in surface-grown single-walled carbon nanotubes, Nanoscale, pp.7394-7398, 2012. ,
Diameter tuning of single-walled carbon nanotubes with reaction temperature using a CO monometallic catalyst, J. Phys. Chem. C, vol.113, pp.10070-10078, 2009. ,
Key roles of carbon solubility in single-walled carbon nanotube nucleation and growth, Nanoscale, issue.7, pp.20284-20289, 2015. ,
Synergism of Co and Mo in the catalytic production of single-wall carbon nanotubes by decomposition of CO, PERGAMON Carbon, vol.39, pp.547-558, 2001. ,
A scalable process for production of single-walled carbon nanotubes (SWNTs) by catalytic disproportionation of CO on a solid catalyst, J. Nanoparticle Res, vol.4, pp.131-136, 2002. ,
Selective synthesis combined with chemical separation of single-walled carbon nanotubes for chirality selection, J. Am. Chem. Soc, vol.129, pp.15770-15771, 2007. ,
Synthesis of subnanometer-diameter vertically aligned single-walled carbon nanotubes with copperanchored cobalt catalysts, Nanoscale, vol.8, pp.1608-1617, 2016. ,
Fluorescence spectroscopy of single-walled carbon nanotubes synthesized from alcohol, Chem. Phys. Lett, vol.387, pp.198-203, 2004. ,
Environmental transmission electron microscopy investigations of Pt-Fe203 nanoparticles for nucleating carbon nanotubes, Carbon N. Y, vol.110, pp.243-248, 2016. ,
FeTiO based catalyst for large-chiral-angle single-walled carbon nanotube growth, Carbon N. Y, vol.107, pp.865-871, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01426080
Chiralselective growth of single-walled carbon nanotubes on Fe-based catalysts using CO as carbon source, Carbon N. Y, vol.108, pp.521-528, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01714535
Chirality-specific growth of single-walled carbon nanotubes on solid alloy catalysts, Nature, vol.510, pp.522-526, 2014. ,
Chirality specifie and spatially uniform synthesis of single-walled carbon nanotubes from a sputtered Co-W bimetallic catalyst, Nanoscale, vol.8, pp.14523-14529, 2016. ,
Structural chemistry of polynuclear transition metal cyanides, Inorg. Chem, pp.1-21, 1973. ,
High-quality single-walled carbon nanotubes synthesis by hot filament CVD on Ru nanoparticle catalyst, Thin Solid Films, vol.519, pp.4594-4597, 2011. ,
Direct Synthesis and Integration of lndividual, Diameter-Controlled Single-Walled Nanotubes (SWNTs), vol.26, pp.5074-5082, 2014. ,
Spontaneous stabilization and isolation of dispersible bimetallic coordination nanoparticles of CsxNi[Cr(CN)6]y, J. Mater. Chem, vol.16, p.2593, 2006. ,
Cyanidebridged Criii-Nill superparamagnetic nanoparticles, Adv. Mater, vol.15, pp.826-829, 2003. ,
Creation of Nanostructures with Poly(methyl methacrylate) -Mediated Nanotransfer Printing, J. Am. Chem. Soc, vol.130, pp.12612-12613, 2008. ,
Metal-film-assisted ultra-clean transfer ofsingle-walled carbon nanotubes, Nano Res, vol.7, pp.981-989, 2014. ,
Core-multishell magnetic coordination nanoparticles: Toward multifunctionality on the nanoscale, Angew. Chemie-Int. Ed, vol.48, pp.183-187, 2009. ,
Nanoengineering NixFelx Catalysts for Gas-Phase, Selective Synthesis of Semiconducting Single-Walled Carbon Nanotubes, ACS Nano, vol.3, pp.4023-4032, 2009. ,
Growth of carbon nanotubes by atmospheric pressure plasma enhanced chemical vapor deposition using NiCr catalyst, Surf. Coatings Technol, vol.201, pp.5378-5382, 2007. ,
Effect ofPretreatment on the Deposition of Carbon Nanotubes by Using Atmospheric-Pressure Plasma-Enhanced Chemical-Vapor Deposition, J. Korean Phys. Soc, vol.47, pp.463-468, 2005. ,
Sequential growth at the sub 10 nm scale of cyanide bridged coordination networks on inorganic surfaces, Dalt. Trans, vol.42, pp.15835-15845, 2013. ,
, Ni-Ru (Nickel-Ruthenium), vol.30, p.412, 2009.
Modeling ofNi-Cr-Mo based alloys: Part 1-phase stability, Calphad Comput. Coupling Phase Diagrams Thermochem, vol.30, pp.70-87, 2006. ,
, The Fe-Ni (Iron-Nickel) system, Bull. Alloy Phase Diagrams, vol.2, p.102, 1981.
, Binary alloy phase diagrams, 1990.
Raman spectroscopy of carbon nanotubes, Phys. Rep, vol.409, pp.47-99, 2005. ,
Structural (n,m) Determination of Isolated Single-Wall Carbon Nanotubes by Resonant Raman Scattering, Phys. Rev. Lett, vol.86, pp.1118-1121, 2001. ,
Linking growth mode to lengths of single-walled carbon nanotubes, Carbon N. Y, vol.113, pp.231-236, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01432079
