, Spectral Methods for Uncertainty Quantification, Scientific Computation, 2010.
The Wiener-Askey Polynomial Chaos for Stochastic Differential Equations, SIAM Journal on Scientific Computing, vol.24, issue.2, pp.619-644, 2002. ,
Numerical methods for Stochastic Computations: a spectral method approach, 2010. ,
Adaptive sparse polynomial chaos expansion based on least angle regression, Journal of Computational Physics, vol.230, issue.6, pp.2345-2367, 2011. ,
Multi-output local gaussian process regression: Applications to uncertainty quantification, Journal of Computational Physics, vol.231, issue.17, pp.5718-5746, 2012. ,
Probabilistic sensitivity analysis of complex models: a bayesian approach, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.66, issue.3, pp.751-769, 2004. ,
Gaussian processes with built-in dimensionality reduction: Applications to high-dimensional uncertainty propagation, Journal of Computational Physics, vol.321, pp.191-223, 2016. ,
Active subspace methods in theory and practice: applications to kriging surfaces, SIAM Journal on Scientific Computing, vol.36, issue.4, pp.1500-1524, 2014. ,
Polynomial meta-models with canonical low-rank approximations: Numerical insights and comparison to sparse polynomial chaos expansions, Journal of Computational Physics, vol.321, pp.1144-1169, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01432141
Applied dynamic programming, 2015. ,
A decomposition-based approach to uncertainty analysis of feed-forward multicomponent systems, International Journal for Numerical Methods in Engineering, vol.100, issue.13, pp.982-1005, 2014. ,
A lanczos method for approximating composite functions, Applied Mathematics and Computation, vol.218, issue.24, pp.11751-11762, 2012. ,
Efficient uncertainty propagation for network multiphysics systems, International Journal for Numerical Methods in Engineering, vol.99, issue.3, pp.183-202, 2014. ,
Red-Horse, Dimension reduction in stochastic modeling of coupled problems, International Journal for Numerical Methods in Engineering, vol.92, issue.11, pp.940-968, 2012. ,
Extreme value oriented random field discretization based on an hybrid polynomial chaos expansion -kriging approach, Computer Methods in Applied Mechanics and Engineering, vol.332, pp.540-571, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01712026
Efficient global multidisciplinary optimization based on surrogate models, Multidisciplinary Analysis and Optimization Conference, pp.367-377, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-02056874
A flexible uncertainty quantification method for linearly coupled multi-physics systems, Journal of Computational Physics, vol.248, pp.383-401, 2013. ,
A flexible uncertainty propagation framework for general multiphysics systems, SIAM/ASA Journal on Uncertainty Quantification, vol.4, issue.1, pp.218-243, 2016. ,
Uncertainty quantification and integration in engineering systems, 2012. ,
Deep gaussian processes, pp.207-215, 2013. ,
Multiple-step ahead prediction for non linear dynamic systems-a gaussian process treatment with propagation of the uncertainty, Advances in neural information processing systems, vol.15, pp.529-536, 2003. ,
Efficient sequential experimental design for surrogate modeling of nested codes ,
URL : https://hal.archives-ouvertes.fr/hal-01657827
The origins of kriging, Mathematical Geology, vol.22, issue.3, pp.239-252, 1990. ,
Uncertainty propagation using infinite mixture of gaussian processes and variational bayesian inference, Journal of Computational Physics, vol.284, pp.291-333, 2015. ,
Gaussian processes for machine learning, 2006. ,
Near-optimal sensor placements in gaussian processes: Theory, efficient algorithms and empirical studies, Journal of Machine Learning Research (JMLR), vol.9, pp.235-284, 2008. ,
Interpolation of spatial data: some theory for kriging, 2012. ,
Variance based sensitivity analysis of model output. design and estimator for the total sensitivity index, Computer Physics Communications, vol.181, issue.2, pp.259-270, 2010. ,
Making best use of model evaluations to compute sensitivity indices, Physics Communications, vol.145, issue.2, pp.280-297, 2002. ,
Comparison of three methods for selecting values of input variables in the analysis of output from a computer code, Technometrics, vol.21, issue.2, pp.239-245, 1979. ,
On the distribution of points in a cube and the approximate evaluation of integrals, USSR Computational Mathematics and Mathematical Physics, vol.7, issue.4, pp.86-112, 1967. ,
The design and analysis of computer experiments, 2013. ,
Design and analysis of computer experiments, Statistical science, pp.409-423, 1989. ,
Statistics for spatial data, 2015. ,
An exact algorithm for maximum entropy sampling, Operations Research, vol.43, issue.4, pp.684-691, 1995. ,
Designs for computer experiments, Technometrics, vol.31, issue.1, pp.41-47, 1989. ,
Near-optimal sensor placements in gaussian processes: Theory, efficient algorithms and empirical studies, Journal of Machine Learning Research, vol.9, pp.235-284, 2008. ,
Sequential design with mutual information for computer experiments (mice): emulation of a tsunami model, SIAM/ASA Journal on Uncertainty Quantification, vol.4, issue.1, pp.739-766, 2016. ,
Computer experiments and global optimization, 1997. ,
Kriging Is Well-Suited to Parallelize Optimization, pp.131-162, 2010. ,
URL : https://hal.archives-ouvertes.fr/emse-00436126
Parallelizing exploration-exploitation tradeoffs in gaussian process bandit optimization, The Journal of Machine Learning Research, vol.15, issue.1, pp.3873-3923, 2014. ,
Fast parallel krigingbased stepwise uncertainty reduction with application to the identification of an excursion set, Technometrics, vol.56, issue.4, pp.455-465, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00641108
Differential evolution -a simple and efficient heuristic for global optimization over continuous spaces, J. Global Optimization, vol.11, pp.341-359, 1997. ,
Gaussian processes for active data mining of spatial aggregates, Proceedings of the 2005 SIAM International Conference on Data Mining, pp.427-438, 2005. ,
, Methodological advances and innovative applications of sensitivity analysis, vol.79, pp.187-193, 2001.
An importance quantification technique in uncertainty analysis for computer models, Proceedings. First International Symposium on Uncertainty Modeling and Analysis, pp.398-403, 1990. ,
Simulation of the ariane 5 epc reentry with the fragmentation tool suite, 7th European Conference on Space Debris, ESA, 2017. ,
Adryans R v5.0 -a 1-dimension object oriented survivability tool, 7th European Conference on Space Debris, ESA, 2017. ,
Efficient global optimization of expensive black-box functions, Journal of Global optimization, vol.13, issue.4, pp.455-492, 1998. ,
Quantile-based optimization under uncertainties using adaptive kriging surrogate models, Structural and Multidisciplinary Optimization, vol.54, pp.1403-1421, 2016. ,
