Cross-scene trajectory level intention inference using Gaussian process regression and naive registration, 2018. ,
Novel Solutions and Applications to Elevator-like Problems, Canada, 2018. ,
On Solving Single Evelatior-like Problems using Learning Automata, 2019. ,
Learning Automata-based Solutions to the Multi-Elevator Problem, 2019. ,
Applying continuous action reinforcement learning automata (carla) to global training of hidden markov models, Proceedings. ITCC 2004. International Conference on, vol.2, pp.638-642, 2004. ,
New learning automata based algorithms for adaptation of backpropagation algorithm parameters, International Journal of Neural Systems, vol.12, issue.01, pp.45-67, 2002. ,
An ACO model for a non-stationary formulation of the single elevator problem, Journal of Computer Science & Technology, vol.7, issue.1, 2007. ,
Learning Automata: An Introduction Prentice-Hall, 1989. ,
Learning automata-based bus arbitration for shared-medium ATM switches, IEEE Transactions on Systems, Man, and Cybernetics, vol.32, issue.6, pp.815-820, 2002. ,
Discretized pursuit learning automata. Systems, Man and Cybernetics, IEEE Transactions on, vol.20, issue.4, pp.931-938, 1990. ,
Continuous learning automata solutions to the capacity assignment problem, IEEE Transactions on Computers, vol.49, issue.6, pp.608-620, 2000. ,
Optimal parking of idle elevators under myopic and state-dependent policies, European Journal of Operational Research, vol.170, issue.3, pp.863-886, 2006. ,
Estimation of optimal elevator scheduling performance, Proceedings -IEEE International Conference on Robotics and Automation, pp.1078-1083, 2006. ,
Dynamic optimization of the operation of single-car elevator systems with destination hall call registration: Part I. Formulation and simulations, European Journal of Operational Research, vol.167, issue.2, pp.550-573, 2005. ,
Dynamic optimization of the operation of single-car elevator systems with destination hall call registration: Part II. The solution algorithm, European Journal of Operational Research, vol.167, issue.2, pp.550-573, 2005. ,
A study on objective functions for dynamic operation optimization of a single-car elevator system with destination hall call registration, Conference Proceedings -IEEE International Conference on Systems, Man and Cybernetics, vol.7, pp.6274-6279, 2004. ,
A new approach to the design of reinforcement schemes for learning automata, IEEE Transactions on Systems, Man, and Cybernetics SCM, vol.15, issue.1, pp.168-175, 1985. ,
A class of rapidly converging algorithms for learning automata, IEEE Int. Conf. on Systems, Man and Cybernatics, 1984. ,
Estimator algorithms for learning automata, Platinum Jubilee Conference on Systems and Signal Processing, 1986. ,
On behaviour of finite automata in random medium, Avtomat. i Telemekh, vol.22, issue.10, pp.1345-1354, 1961. ,
On the behavior of stochastic automata with a variable structure, Avtomatika i Telemekhanika, vol.24, issue.3, pp.353-360, 1963. ,
Single Elevator Scheduling Problem with Complete Information : An Exact Model using Mixed Integer Linear Programming, pp.2894-2899, 2016. ,
