Automatic subspace clustering of high dimensional data, 2005. ,
Multidimensional scaling, Handbook of Data Visualization, pp.315-347, 2008. ,
Clustering high-dimensional data: A survey on subspace clustering, pattern-based clustering, and correlation clustering, ACM Transactions on Knowledge Discovery from Data, vol.3, issue.1, pp.1-58, 2009. ,
Minimum density hyperplanes, Journal of Machine Learning Research, vol.17, issue.156, pp.1-33, 2016. ,
Nonlinear component analysis as a kernel eigenvalue problem, Neural Computation, vol.10, issue.5, pp.1299-1319, 1998. ,
Enhancing principal direction divisive clustering, Pattern Recognition, vol.43, issue.10, pp.3391-3411, 2010. ,
A global geometric framework for nonlinear dimensionality reduction, Science, vol.290, issue.5500, pp.2319-2323, 2000. ,
An extended isomap by enhancing similarity for clustering, Advanced Research in Applied Arti_cial Intelligence, vol.7345, pp.808-815, 2012. ,
Localized Data Fusion for Kernel k-Means Clustering with Application to Cancer Biology, Advances in Neural Information Processing Systems 27 (NIPS 2014), 2014. ,
A Tutorial on Spectral Clustering, Statistics and Computing, vol.17, issue.4, p.2007 ,
