Adaptive list organizing strategies for non-stationary distributions, 2004. ,
On the competitive theory and practice of online list accessing algorithms, Algorithmica, vol.32, issue.2, pp.201-245, 2002. ,
Adaptive control processes: A guided tour, 1961. ,
Amortized analyses of self-organizing sequential search heuristics, Communications of the ACM, vol.28, issue.4, pp.404-411, 1985. ,
On Designing Adaptive Data Structures with Adaptive Data "Sub"-Structures, 2018. ,
A fixed structure learning automaton microaggregation technique for secure statistical databases, International Conference on Privacy in Statistical Databases, pp.114-128, 2006. ,
Achieving microaggregation for secure statistical databases using fixed-structure partitioning-based learning automata, IEEE Transactions on Systems, Man, and Cybernetics, vol.39, issue.5, pp.1192-1205, 2009. ,
Improvements to an algorithm for equipartitioning, IEEE Transactions on Computers, vol.39, issue.5, pp.706-710, 1990. ,
Self-organizing linear search, ACM Computing Surveys (CSUR), vol.17, issue.3, pp.295-311, 1985. ,
Self-organizing search lists using probabilistic back-pointers, Communications of the ACM, vol.30, issue.12, pp.1074-1079, 1987. ,
Two results on the list update problem, Information Processing Letters, vol.38, issue.6, pp.301-306, 1991. ,
Learning Automata: An Introduction, Courier Corporation, 2012. ,
Deterministic learning automata solutions to the equipartitioning problem, IEEE Transactions on Computers, vol.37, issue.1, pp.2-14, 1988. ,
Stochastic automata solutions to the object partioning problem, The Comput. Journal, vol.35, 1992. ,
On self-organizing sequential search heuristics, Communications of the ACM, vol.19, issue.2, pp.63-67, 1976. ,
Novel Solutions and Applications of the Object Partitioning Problem, 2018. ,
Amortized efficiency of list update and paging rules, Communications of the ACM, vol.28, issue.2, pp.202-208, 1985. ,
Two spectra of self-organizing sequential search algorithms, SIAM Journal on Computing, vol.11, issue.3, pp.557-566, 1982. ,
Learning from delayed rewards, 1989. ,
Adaptive clustering schemes: General framework, Proc. of the IEEE COMPSAC Conference, pp.81-89, 1981. ,
