Algebraic graph theory, vol.207, 2013. ,
Algebraic graph theory, 1993. ,
Achieving microaggregation for secure statistical databases using fixed-structure partitioning-based learning automata, IEEE Transactions on Systems, Man, and Cybernetics, vol.39, issue.5, pp.1192-1205, 2009. ,
The object partition problem. Vision Flash, 1971. ,
Improvements to an algorithm for equipartitioning. Computers, IEEE Transactions on, vol.39, issue.5, pp.706-710, 1990. ,
Intelligent traffic-aware consolidation of virtual machines in a data center, 2015. ,
Discretized estimator learning automata, IEEE Transactions on Systems, Man, and Cybernetics, vol.22, issue.6, pp.1473-1483, 1992. ,
A learning automaton based approach for data fragments allocation in distributed database systems, Computer and Information Technology (CIT), pp.8-12, 2010. ,
Stochastic automata solutions to the object partitioning problem, 1986. ,
Continuous and discretized pursuit learning schemes: various algorithms and their comparison, IEEE Transactions on Systems, Man, and Cybernetics, vol.31, issue.3, pp.277-287, 2001. ,
Novel Solutions and Applications of the Object Partitioning Problem, 2018. ,
Service selection in stochastic environments: a learning-automaton based solution, Applied Intelligence, vol.36, issue.3, pp.617-637, 2012. ,
A novel framework for self-organizing lists in environments with locality of reference: Lists-on-lists, The Computer Journal, vol.50, issue.2, pp.186-196, 2007. ,
