Popular Conjectures Imply Strong Lower Bounds for Dynamic Problems, FOCS, pp.434-443, 2014. ,
Fine-Grained Complexity of Analyzing Compressed Data: Quantifying Improvements over Decompress-and-Solve, FOCS, pp.192-203, 2017. ,
If the Current Clique Algorithms are Optimal, So is Valiant's Parser, FOCS, pp.98-117, 2015. ,
New Algorithms and Lower Bounds for All-Pairs Max-Flow in Undirected Graphs, 2019. ,
Matching Triangles and Basing Hardness on an Extremely Popular Conjecture, SIAM J. Comput, vol.47, issue.3, pp.1098-1122, 2018. ,
All-Pairs Min-Cut in Sparse Networks, Journal of Algorithms, vol.29, issue.1, pp.82-110, 1998. ,
Blocking unions of arborescences. CoRR, 2015. ,
, Faster Algorithms for All-Pairs Bounded Min-Cuts
AnÕ(mn) Gomory-Hu Tree Construction Algorithm for Unweighted Graphs, STOC, pp.605-614, 2007. ,
A Dichotomy for Regular Expression Membership Testing, FOCS, pp.307-318, 2017. ,
Clique-Based Lower Bounds for Parsing Tree-Adjoining Grammars, CPM, vol.12, pp.1-12, 2017. ,
All-Pairs Shortest Paths with Real Weights in O(n 3 / log n) Time. Algorithmica, vol.50, pp.236-243, 2008. ,
Conditional Lower Bound for RNA Folding Problem, 2015. ,
Graph Connectivities, Network Coding, and Expander Graphs, SIAM Journal on Computing, vol.42, issue.3, pp.733-751, 2013. ,
Matrix multiplication via arithmetic progressions, Journal of Symbolic Computation, vol.9, issue.3, pp.251-280, 1990. ,
On the complexity of fixed parameter clique and dominating set, Theor. Comput. Sci, vol.326, issue.1-3, pp.57-67, 2004. ,
Boolean matrix multiplication and transitive closure, SWAT, pp.129-131, 1971. ,
, Flows in Networks, 1962.
All-Pairs 2-Reachability in O(n ? log n) Time, ICALP, vol.80, pp.1-74, 2017. ,
Multi-Terminal Network Flows, Journal of the Society for Industrial and Applied Mathematics, vol.9, issue.4, pp.551-570, 1961. ,
Efficient Algorithms for Computing All Low s-t Edge Connectivities and Related Problems, SODA, pp.127-136, 2007. ,
Conditional Lower Bounds for All-Pairs Max-Flow, ACM Trans. Algorithms, vol.14, issue.4, 2018. ,
Single Source -All Sinks Max Flows in Planar Digraphs, FOCS, pp.599-608, 2012. ,
Powers of Tensors and Fast Matrix Multiplication, ISSAC, pp.296-303, 2014. ,
Path Finding Methods for Linear Programming: Solving Linear Programs in O( ? rank) Iterations and Faster Algorithms for Maximum Flow, FOCS, pp.424-433, 2014. ,
Tight Hardness for Shortest Cycles and Paths in Sparse Graphs, SODA, pp.1236-1252, 2018. ,
Computing Maximum Flow with Augmenting Electrical Flows, FOCS, pp.593-602, 2016. ,
Parameterized graph separation problems, Theoretical Computer Science, vol.351, issue.3, pp.394-406, 2006. ,
, Zur allgemeinen Kurventheorie. Fundamenta Mathematicae, vol.10, issue.1, pp.96-115, 1927.
Minimum cost subpartitions in graphs, Inf. Process. Lett, vol.102, issue.2-3, pp.79-84, 2007. ,
On the complexity of the subgraph problem. Commentationes Mathematicae Universitatis Carolinae, vol.26, pp.415-419, 1985. ,
Gomory-Hu trees, Encyclopedia of Algorithms, pp.858-861, 2016. ,
Efficient algorithms for clique problems, Inf. Process. Lett, vol.109, issue.4, pp.254-257, 2009. ,
Multiplying Matrices Faster Than Coppersmith-Winograd, STOC, pp.887-898, 2012. ,
Subcubic Equivalences Between Path, Matrix, and Triangle Problems, J. ACM, vol.65, issue.5, 2018. ,
An improved combinatorial algorithm for Boolean matrix multiplication, Inf. Comput, vol.261, pp.240-247, 2018. ,
