Solutions to shape and topology eigenvalue optimization problems using a homogenization method, International Journal for Numerical Methods in Engineering, vol.35, issue.7, pp.1487-1502, 1992. ,
Structural design for obtaining desired eigenfrequencies by using the topology and shape optimization method, Computing Systems in Engineering, vol.5, issue.1, pp.77-89, 1994. ,
Structural optimization using sensitivity analysis and a level-set method, Journal of computational physics, vol.194, issue.1, pp.363-393, 2004. ,
Structural optimization using topological and shape sensitivity via a level set method, Control and Cybernetics, vol.34, issue.1, p.59, 2005. ,
Structural topology optimization with eigenvalues, SIAM Journal on Optimization, vol.18, issue.4, pp.1129-1164, 2007. ,
Aerodynamic shape optimization using the adjoint method, 2003. ,
Shape derivatives for the compressible Navier-Stokes equations in variational form, Journal of Computational and Applied Mathematics, vol.296, pp.334-351, 2016. ,
Topology optimization of photonic crystal structures: a high-bandwidth low-loss T-junction waveguide, Journal of Optical Soscity of America B, vol.22, issue.6, pp.1191-1198, 2005. ,
Robust topology optimization of photonic crystal waveguides with tailored dispersion properties, Journal B: Optical Physics, vol.28, issue.3, pp.387-397, 2011. ,
Shape optimization of an acoustic horn, Computer Methods in Applied Mechanics and Engineering, vol.192, issue.11, pp.1533-1571, 2003. ,
Optimization of an acoustic horn with respect to efficiency and directivity, International Journal for Numerical Methods in Engineering, vol.73, issue.11, pp.1571-1606, 2008. ,
Shape and topology optimization of an acoustic horn-lens combination, Journal of Computational and Applied Mathematics, vol.234, issue.6, pp.1781-1787, 2010. ,
Optimization of a variable mouth acoustic horn, International Journal for Numerical Methods in Engineering, vol.85, issue.5, pp.591-606, 2011. ,
Acoustic shape optimization using cut finite elements, International Journal for Numerical Methods in Engineering, vol.113, issue.3, pp.432-449, 2018. ,
Shape optimization of a Helmholtz resonator using an adjoint method, International Journal of Spray and Combustion Dynamics, vol.9, issue.4, pp.394-408, 2017. ,
Acoustic design by topology optimization, Journal of Sound and Vibration, vol.317, issue.3-5, pp.557-575, 2008. ,
Topology optimization in acoustics and elasto-acoustics via a level-set method, Journal of Sound and Vibration, vol.420, pp.73-103, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01957243
Acoustic boundary layers as boundary conditions, Journal of Computational Physics, vol.371, pp.633-650, 2018. ,
Hybrid numerical and analytical solutions for acoustic boundary problems in thermo-viscous fluids, Journal of Sound and Vibration, vol.263, issue.1, pp.69-84, 2003. ,
Shape optimization of micro-acoustic devices including viscous and thermal losses, Journal of Sound and Vibration, 2019. ,
Thickness control in structural optimization via a level set method, Structural and Multidisciplinary Optimization, vol.53, pp.1349-1382, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-00985000
Solution of ill-posed problems, 1977. ,
A computational framework for the regularization of adjoint analysis in multiscale PDE systems, Journal of Computational Physics, vol.195, issue.1, pp.49-89, 2004. ,
Minimization of functions having Lipschitz continuous first partial derivatives, Pacific Journal of Mathematics, vol.16, issue.1, pp.1-3, 1966. ,
A finite element method for crack growth without remeshing, International Journal for Numerical Methods in Engineering, vol.46, issue.1, pp.131-150, 1999. ,
High order X-FEM and levelsets for complex microstructures: uncoupling geometry and approximation, Computer Methods in Applied Mechanics and Engineering, vol.241, pp.172-189, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00703239
CutFEM: discretizing geometry and partial differential equations, International Journal for Numerical Methods in Engineering, vol.104, issue.7, pp.472-501, 2015. ,
Ghost penalty, Comptes Rendus Mathematique, vol.348, pp.1217-1220, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00543248
Finite element methods for flow problems, 2003. ,
Level set methods: an overview and some recent results, Journal of Computational physics, vol.169, issue.2, pp.463-502, 2001. ,
Distance regularized level set evolution and its application to image segmentation, IEEE Transactions on Image Processing, vol.19, issue.12, pp.3243-3254, 2010. ,
Analysis of discrete ill-posed problems by means of the L-curve, SIAM review, vol.34, issue.4, pp.561-580, 1992. ,
