An improved impedance eduction technique based on impedance models and the mode matching method, Applied Acoustics, vol.129, pp.322-334, 2018. ,
Design of silencer using resonator arrays with high sound pressure and grazing flow, Applied Acoustics, vol.138, pp.188-198, 2018. ,
Calculation of perforated plate liner parameters from specified acoustic resistance and reactance, Journal of Sound and Vibration, vol.40, issue.1, pp.119-137, 1975. ,
Potential of microperforated panel absorber, p.6, 1998. ,
Sound absorbing materials, 1949. ,
The propagation of plane sound waves in narrow and wide circular tubes, and generalization to uniform tubes of arbitrary cross-sectional shape, The Journal of the Acoustical Society of America, vol.89, issue.2, pp.550-558, 1991. ,
, Theoretical Acoustics, 1968.
Absorption Characteristics of Nonlinear Acoustic Resonators, The Journal of the Acoustical Society of America, vol.44, issue.4, pp.1155-1156, 1968. ,
Acoustics: An Introduction to its Physical Principles and Applications, 1981. ,
Optimisation géométrique du contrôle actif dans les gaines de ventilation, École Nationale des Ponts et Chaussées, 1996. ,
The acoustic impendance of perforates at medium and high sound pressure levels, Journal of Sound and Vibration, vol.29, issue.1, pp.1-65, 1973. ,
Theoretical research of the conductivity of a circular aperture in a partition across a pipe, Doklady akademii nauk SSSR, vol.31, issue.9, pp.875-82, 1941. ,
Aircraft Fan Noise Absorption: DNS of the Acoustic Dissipation of Resonant Liners, 15th AIAA/CEAS Aeroacoustics Conference (30th AIAA Aeroacoustics Conference), 2009. ,
Computational Fluid Dynamics -An introduction: With contributions by, 2009. ,
Gmsh: a three-dimensional finite element mesh generator with built-in pre-and post-processing facilities, International Journal for Numerical Methods in Engineering, vol.79, issue.11, pp.1309-1331, 2009. ,
GetFEM++. An Open Source Finite Element Library, 2017. ,
An introduction to fluid dynamics, Cambridge mathematical library, p.838184093, 2010. ,
Simulation numérique de l'absorption acoustique de matériaux résonnants en présence d'écoulement, 2011. ,
Fundamentals of acoustics, p.255489082 ,
URL : https://hal.archives-ouvertes.fr/hal-00078957
Mathematical Justification of the Rayleigh Conductivity Model for Perforated Plates in Acoustics, SIAM Journal on Applied Mathematics, vol.73, issue.1, pp.438-459, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00860712
Effective conditions for the reflection of an acoustic wave by low-porosity perforated plates, Journal of Fluid Mechanics, vol.743, pp.448-480, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00769393
Transfer function of small convergent-divergent (C-D) nozzles and opposite (D-C) devices filled with thermo-viscous fluid at rest, Applied Acoustics, vol.99, pp.118-124, 2015. ,
